W 208 help clk 55 amg
Old Dec 1, 2013 | 06:11 PM
Ti8kitti's Avatar
2001 clk 55 amg
sweet
Old Dec 2, 2013 | 07:16 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Originally Posted by Ti8kitti
I ve been visiting this site for well over a year, let me start by saying you boys crack me up
I have a 2001 clk 55 amg with 48000 miles I got it with 34000, it's branded. ): I will say this it's never died on me nor left me stuck. I m hopefully picking up another one on Monday not branded.
Now that I ve introduced my self, I have a question well more like a few all based around the same ideas PLEASE HELP... Okay here goes
Does the ac / cooling system affect the way the car drives? (Loss of power) etc.
I ve read that a radiator can take out a transmission?
I m 32 years old and have never even thought about cars until I got my hands on 55 w208 I fell in love.
Yet I m smarter that most shops I ve gone into so I don't trust jus anyone and yet every one I know tells me that the ac/ cooling system will not effect my car but in my gut I feel like because there is something wrong with mine it's killing my car????
Can any one tell me if I'm on to something here?
I turn on defrost or heat a awful smell comes in thru vents yet if I recycle the heater I don't smell it ?
Also a leak in the radiator a slow leak the over flow stayed full all summer as soon as it got cold and rainy the over flow was almost empty and than I fill it than check it the day after only starting the car no driving and it was to full???
I also got the codes from climate control # 7 is @(4)
Plz any insight or information would really put my mind to rest I m driving my self crazy!!!
Thank you so much
Sorry, at the outset "branded" v. "Not branded", what do you mean exactly? Second, in terms of AC affecting my engine performance, no. In terms of the horrid smell it might be time to change the cabin air filter. Radiator leak if it is brass get it fixed if not get it replaced. Good luck.
Old Dec 2, 2013 | 08:16 AM
keninblaine's Avatar
2015 Macan S; 1996 911 C4S
I expect branded means the same as salvage title.
For "horrid smell", I would suspect mildew/mold in the AC evaporator. It is hard to conceive of this big motor being noticeably affected by the AC system, unless something like the compressor is getting seized up and putting a bigger load on the motor than normal. Hopefully, it is just an overactive imagination issue.
Old Dec 2, 2013 | 02:40 PM
Ti8kitti's Avatar
2001 clk 55 amg
;p
Old Dec 2, 2013 | 02:48 PM
Ti8kitti's Avatar
2001 clk 55 amg
;p
Old Dec 5, 2013 | 10:13 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
sounds like the heater core or a loose heater hose connection under the dash.
The AC compressor might be getting tight as well
Posted from Mbworld.org App for Android
Old Dec 7, 2013 | 01:28 PM
Ti8kitti's Avatar
2001 clk 55 amg
My babies clk 55 amgs
I want them to be the best the black top only 47000 miles
Old Dec 7, 2013 | 01:35 PM
Ti8kitti's Avatar
2001 clk 55 amg
Still
Trying to figure out this site lol
Old Dec 8, 2013 | 04:23 PM
Ti8kitti's Avatar
2001 clk 55 amg
Any better ideas for educational books👉💜👈
😍 reading
Old Dec 15, 2013 | 08:45 PM
GatorMB's Avatar
There is a fan controller for the electric fans that might be acting up,
Your symptoms are not real clear and are for various systems.
Clarity will get you some positive results, These cars are not real 1st time DIY friendly.
There is a post in here about a turbo diesel asking about excessive whistling under acceleration. This is an AMG V8 gasser forum. It is funny but we all do it.
All the Best, Gator
Old Dec 15, 2013 | 09:22 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
To start Freon is low if #7 is showing 4, cabin filter should be changed. Coolant lose, well check for leaks, check transmission for coolant seeping into the trans oil, think that was a problem in the early years. Fan will go to high speed if the AC is turned on especially if the car is up to temp and the outside temp is high, this prevents overheating of the engine and makes the AC work better. Recycling just reuses the inside air in the cabin and does not draw from the outside through the cabin filter, Good Luck
Old Dec 30, 2013 | 06:13 AM
Ti8kitti's Avatar
2001 clk 55 amg
1
Old Dec 30, 2013 | 09:39 AM
Chadzu's Avatar
2001 Clk55 AMG
Front wheel bearings loosen up over time. They can be adjusted if bearings are still good. Lower ball joints develop slop and need replacing. The steering damper fails and can cause weird feel at steering wheel. These are all straight forward repairs, any decent shop or home mechanic should have no problems.
Old Dec 30, 2013 | 01:07 PM
MarcusF's Avatar
2002 CLK430
@OP - When you have more than two questions, it may be better to number them. Here’s an example
1. Can a bad radiator take out my transmission?
2. Does the AC impact performance?
3. Why does my HVAC fan make so much noise?
4. Why does my car reek with the heater on?
5. What exhaust can I use that won’t sound like a ricer exhaust?
6. What’s the difference between my two CLK55s? One is fast one is slow.
Etc.
This allows people who know specific answers to address them individually. For example:
1. Yes, but that’s more common for 2003 and early 2004 W209 CLKs. A pressure test will tell you for sure. Alternatively, the radiator is 10 years old. It's going to have to be replaced at some point. You may want to do it now.
2. Technically yes. However, it's highly doubtful you would notice AND at wide open throttle the compressor is electronically disengaged.
3. Like Gator said, it sounds like the blower motor regulator. Here's a DIY link.
4. That is commonly caused by the cabin filter or a clogged air intake drain hole.
6. If the two cars are both W208 CLK55s, they are the same. One is broken. The busted one sounds like it has a bad MAF or a bad speed sensor, or the TPS has gone south. The MAF is a normal wear item, but with a salvaged title, it could be anything. Does the broken car perform the same with the ESP turned off? If it runs much better w/o ESP, then I'd guess there's a speed sensor issue.
I hope that helps
Old Dec 30, 2013 | 03:31 PM
Ti8kitti's Avatar
2001 clk 55 amg
1
Old Dec 30, 2013 | 03:41 PM
MarcusF's Avatar
2002 CLK430
The steering gear bolt service is very easy to overlook. Thankfully, it's even easier to perform.
Old Dec 30, 2013 | 11:55 PM
Ti8kitti's Avatar
2001 clk 55 amg
Thx you for all your help
