clk 430 AMG brake upgrade?
Old Aug 22, 2015 | 12:18 AM
santagtmb's Avatar
w208 430
Question clk 430 AMG brake upgrade?
i have a 2001 clk 430, im trying to upgrade the brakes with out spending a lots of money... i wonder if a 4 pot brake calipers from any other mercedes will fit mine???:
like the ones in the ML55 amg suv .
Old Aug 24, 2015 | 05:56 PM
cm60k's Avatar
If you want direct bolt-on, you can go with "W202 C43/W208 CLK55/W210 E55" brakes,
no need any mods for fitment..
ZAYED,,
Old Aug 25, 2015 | 08:11 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Keep in mind that your stock 17" wheels will probably not have enough room to clear a big brake upgrade.
Old Aug 25, 2015 | 11:22 AM
cm60k's Avatar
With 2-pot F&R C43/CLK55 brakes will fit with 17", but with 4-pot C32/C55 brakes it might be, need to try them..
ZAYED,,
Old Aug 25, 2015 | 09:06 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
The c32/55 come with 17inch rims stock
Old Aug 25, 2015 | 09:07 PM
ProjectC55's Avatar
depends on which 17 inch mb rims you use
Old Aug 26, 2015 | 08:34 AM
insame1's Avatar
The C55 comes on 18"s like the face lifted 209 clk55s
Old Aug 26, 2015 | 02:13 PM
sick430's Avatar
CLK Cabrio
Im running the CLK430 17's (track rims) and have the c32/c55/clk550 (all use the same caliper) calipers and rotors. Mine are specifically from a c55. with that said I only have a few mm of clearance on the spokes. I am running a square setup with 8 1/2 all around.
Attached Thumbnails clk 430 AMG brake upgrade?-img_2114.jpg   clk 430 AMG brake upgrade?-img_8428.jpeg
Old Aug 26, 2015 | 02:37 PM
cm60k's Avatar
Excellent, you make it sooooo easy..
ZAYED,,
Old Aug 30, 2015 | 09:39 AM
astamir's Avatar
mercedes CLK55 AMG
that is exactly i was going to do on my clk55 can you share with us the brakeing performance expirience after the brake upgrade?
thanks
Old Sep 17, 2015 | 11:09 PM
DaSkorpion's Avatar
o2 CLK 55 AMG || o4 Audi A4 6SP Quattro || o7 Kawasaki Ninja ZX10R
@santagtmb - I have a pair of used w208 clk 55 amg front calipers for sale if you're interested.
Old Sep 18, 2015 | 01:28 PM
sick430's Avatar
CLK Cabrio
Those are different than the ones the OP is talking about.
Old Sep 20, 2015 | 06:12 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
The W209 calipers and rotors are more forgiving in price and apply to upgrade brembos.
W208 rotors and calipers are priced out of existence.I just forked over $500 for oem stugart Zimmerman rotors.
The W209 were a bit larger in diameter and the calipers should clear. only pending thought is you are a non AMG and the Caliper brackets/spindle might be totally different.
I would investigate part numbers for the 430 vs 55 as to compatibility.
Old Sep 21, 2015 | 01:17 PM
sick430's Avatar
CLK Cabrio
Same part
Old Oct 13, 2020 | 06:16 PM
lumanikus's Avatar
w208 CLK430 2002
Bringing it back from the dead because I just want to pull the trigger and finally get this done.
The calipers I have on hand are 207047048 which I 'think' are to a 2004 CL500. I checked the fitment on the calipers and they are fine but will need spacers I believe. Will stock CL500 rotors work in this case?
tia
