does the radio antenna also operate centrol locking
Old Jul 3, 2017 | 02:15 PM
Joseph Enguita's Avatar
clk240 convertable 2004
clk240 w209 since keyfob stopped working iam having trouble with radio dropping stations
Old Jul 3, 2017 | 09:30 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
no
Old Jul 7, 2017 | 12:11 PM
i'm sure the keyfob uses af antenna to operate locking system from a distance
Old Jul 9, 2017 | 04:03 PM
GatorMB's Avatar
The Key fob is tied to the antenna is equivalent to mixing beer and chocolate milk
Old Jul 10, 2017 | 06:47 PM
MacVidMB-V8's Avatar
W209, W124
Probably should know what you're talking about before posting.
RF part of Key uses antenna and amplifier to work.
Common failure mode is losing radio reception when RF part of key fob stops.
Search and you shall find answers.
Sometimes amp loses connection to glass, sometimes fuse blows.
Old Jul 10, 2017 | 07:01 PM
GatorMB's Avatar
I am not buying it,
You could power up a Nav head on a workbench and still bluetooth chuck berry. These systems are totally independent.
The FOB is only for determining the next available immobilizer enable. Yhe batteries in the FOB are for Central Locking System only. Infra red in the Ignition FOB hole determines immobilizer enable to start.
All correction queries welcome but might get beyond the scope of the OP question which seems meaningless to me.
The Antenna operates off a relay when the radio is powered on if this makes ant sense.
Hit me hard folks, Gator
Old Jul 10, 2017 | 07:15 PM
W209, W124
I am not buying it,
I'll give you benefit of the doubt, you have a W208 and are fully ignorant of anything about W209.
W209 uses ant amp for RF part of key. Simple, easily confirmed fact.
Old Jul 10, 2017 | 07:38 PM
GatorMB's Avatar
Ill take a sweet note any day of the week but MB Audio amps are all over e-bay.
A radio will work without an amp and most of its NAV data comes over the D2B Most Bus.
None of it has ever tied into central locking system or Antenna control. NAV uses Fiber independent of Fob Enable. The only close possibility is a panic button hit.
Likely only operates security siren unless one subscribes to Benz Apps.
The latest radios mabye 2012 and up require owner ID for activation.
You are on track but W209 DVD systems are not that elaborate.
Folks, I am open to abuse give it up.
Cheers, Gator
Old Jul 10, 2017 | 07:56 PM
GatorMB's Avatar
Not doubting this but what antenna. Audio Analog or Digital IR.
Ill eat my cheese.
LOL
Old Jul 10, 2017 | 09:58 PM
W209, W124
Cheers, Gator
You don't even have the mildest clue of what you are talking about.
I wouldn't care but you have given the OP wrong and worthless advice.
There is a thing called "google"
Into it type "W209 antenna radio key" and prepare for true enlightenment.
It takes a real man (or woman) to say "Whoops, I was wrong"
Time to take the test.
If Google is acting up, here is one of the results, leads right back to this board.
https://mbworld.org/forums/c32-amg-c...q-only-ir.html
Old Jul 11, 2017 | 08:24 AM
GatorMB's Avatar
We learn something new every day.
Not sure why the W208/W209 was clumped into the same forum but it is apparent there are hidden discrepancies.
Preparing to eat my hat, ketchup please?
Cheers
