CLK55 oil usage
Old Jul 24, 2017 | 02:22 PM
Muggie's Avatar
CLK55 AMG Convertible (63 rep)
CLK55 oil usage
Hello all, I've got a CLK55 2005 W209 model with 98,000 on the clock. It's a weekend car and I've covered 3000 miles in the last year. My question is roughly how much oil should I be topping it up with? I'm putting 1 litre every 6ish weeks depending on how it's driven. Thanks in advance.
Old Jul 24, 2017 | 02:47 PM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
So you are putting in 1 litre every 350 miles?
That is not normal.
Old Jul 24, 2017 | 03:04 PM
Muggie's Avatar
Thanks for the reply. It doesn't leak, burn or smoke oil so I'm a bit confused. That doesn't sound to good, I'll have to get it looked at. Cheers.
Old Jul 24, 2017 | 03:11 PM
The cats suck up a fair bit of oil smoke so they dont tend to smoke until they really burn a lot of oil.
Are you actually putting a litre in every 350 miles?
Old Jul 24, 2017 | 03:19 PM
Muggie's Avatar
Oh right. To be honest I haven't actually recorded the miles to oil but I will from now as I put a litre in today. This is my first merc coming over from bmw so I haven't got a massive amount of knowledge on these cars so any help is much appreciated. Cheers.
Old Jul 24, 2017 | 03:21 PM
Ah ok, dont stress too much then. Just note it down and see how much you are putting in. Let us know afterwards.
Old Jul 24, 2017 | 03:31 PM
Muggie's Avatar
Will do. Is there other bits I should look out for on these cars? The gearbox rad has already been done and it's got good history. Thanks again.
Old Jul 24, 2017 | 09:06 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
1 litre per month is the rule for a daily driver.
Any car that sits for long periods can easily develop a leak especially when stored outdoors.
When the car sits for long periods the oil is essentially not oil anymore but a condensate collection pit.
If you are topping off after storage it is normal. Might give it a service and report back again if there is no leak evident.
Cheers
Old Jul 24, 2017 | 09:13 PM
Muggie's Avatar
Ok, so I didn't know that. I'll get it booked in for a service, I was also going to have a carbon clean on it as well. Thanks.
Old Jul 24, 2017 | 09:48 PM
GatorMB's Avatar
The headings at our names do not show demographics anymore or car type.
But with oil that sits in constant humidity like where I live requires top maintenance intervals.
Ocean, Sea, Gulf and London Fog air will wrench away on sitting oil. Once the moisture is built up in the oil so much it burns off along with the oil.
Short trip driving where the engine never gets loaded under normal operating temp will load the oil up with condensate as well.
The later is not normally an issue with AMG engines though. We make a sizable amount of KW/HP per Litre
To add oil mixed with water in harmony of combustion creates form of hydrachloric acid which eats away at bearing babbit.
