taking out the rear muff either today or tomorrow and putting in some straight pipes. will give feedback on results and post pics, if possible.
you guys should just slap these in best of both worlds..
http://www.quicktimeperformance.com/QTEC/
small vid of it in action
http://208.254.222.235/QTEC/WRXVideo.wmv
damn redneck video Originally posted by ro0zy
:vMBWorld Fanatic!
yeah but it's still good stuff ..nice and simple mod (and for our c32's ..so you won't lose back pressure/low end performance for having a straight pipes, you can just leave it closed at the start and hit the siwtch on the top end where it would help us a little
)MBWorld Fanatic!
i wonder if it's programmable to open up after certain RPMs and shut below a certain RPMOriginally posted by ro0zy
it's just controlled my a simple on/off switch ..im going to do this and make a vid as soon as i can get the measurements of our pipe
does it makes a differnet if you take off the resonator? because I am planning to take it off too
ExploreAlmost a Member!
Quote:
It should be !Originally posted by AMG BRED
This is want Aston Martin do with the Vanquish. It is programmed to make a loud growl on ignition and start wailing above 3000 rpm (i think) - drool
that's so much work to remember to hit the switch while in the heat of gunning it.. :vOriginally posted by ro0zy
Quote:
Originally posted by pnadin
It should be !
Variable Valve timing should do that.. have you heard the "VTEC" in the NSX past 5000 rpms.. it's pure sex.. i remember seeing a license plate on an NSX that read "XTC AT 5K" Originally posted by pnadin
It should be !
