Good choice for brake pads? 2005 clk55
Old May 28, 2019 | 10:23 AM
JYO's Avatar
JYO
1999 E 320 (sold), 2015 AUdi S5 (sold) 2005 CLK55 Cab, 2016 Honda Pilot Elite, 2011 Jaguar XF
My front rotors are worn down and I am thinking of replacing them with the Brembo part that is similar to the original rotor. I’m assuming that’s a good choice but as far as pads what should I shoot for?
Like to have as close to original stopping power but if there’s an option that throws off less brake dust that’s great too. Appreciate any comments or reviews on what your experience has been.
Old May 28, 2019 | 10:56 AM
cm60k's Avatar
Do you have Front 4-pot or 6-pot calipers..??
-;ZAYED;-
Old May 28, 2019 | 12:08 PM
JYO's Avatar
JYO
6 pot I think according to mechanic How would I tell visually?
Old May 28, 2019 | 12:57 PM
cm60k's Avatar
I personally like "EBC" Red or Yellow pads, using them with many MB models,,
they are really great stopping perform, with NO soft pedal, and less dust compared to OEM's..
-;ZAYED;-
Old May 28, 2019 | 01:04 PM
JYO's Avatar
JYO
thx. where is best place to buy them? And is it worth looking at a different rotor than the Brembo. Truth is I may not keep car much longer
Old May 28, 2019 | 01:31 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Buy it all from fcpeuro so you get the lifetime warranty.
Old May 28, 2019 | 01:33 PM
JYO's Avatar
JYO
Do you have a particular pad you like?
Old May 28, 2019 | 01:51 PM
cm60k's Avatar
Originally Posted by JYO
thx. is it worth looking at a different rotor than the Brembo. Truth is I may not keep car much longer
If you will not keep the car, you can put regular 1-piece Rotors from "C32/C55",,
they are much cheaper..
-;ZAYED;-
Old May 28, 2019 | 06:38 PM
JYO's Avatar
JYO
-;ZAYED;-
Hmmm. I didn’t know that. What is the disadvantage of doing that? Would this one work?
Old May 29, 2019 | 03:27 AM
cm60k's Avatar
Sure, it will works fine,
As you know;
2-piece rotors have better advantages, over 1-piece,
such as:-
"Less weight/better heat dissipation of aluminum hat acting as a heat sink/transfer heat from hub and wheel bearings/more age",,
as long as you will not keep the car, better to go with 1-piece Rotors..
-;ZAYED;-
Old May 29, 2019 | 10:38 AM
JYO's Avatar
JYO
If someone were keeping the car but only drove it on the weekends with some spirited driving but no track use are the one piece rotors OK?
Old May 29, 2019 | 12:29 PM
cm60k's Avatar
Yeah, why not..!
-;ZAYED;-
Old May 29, 2019 | 12:30 PM
j-mo's Avatar
2006 E55 AMG, 2019 BMW M240I xdrive coupe, 1969 Mach 1 Mustang
I have put Akebono ceramics on my 2002 CLK55 and 2006 E55. I love them.
Old May 29, 2019 | 12:33 PM
cm60k's Avatar
Unfortunately;
"Akebono" doesn't have pads for "CLK55/SLK55" Front 6-pot pads,,
they only have for Rears..!!
-;ZAYED;-
Old May 29, 2019 | 01:24 PM
JYO's Avatar
JYO
Zayed what do you like about the EBC pads and what is the diff between red and yellow? Thx
Old May 29, 2019 | 06:31 PM
cm60k's Avatar
Both are great,
A) "Red stuff", is ceramic components/very low dust/around (25%) better stopping brake.
B) "Yellow stuff", is Track racing/heavy brake/minimum Rotor damage due to perfect mixture copper & carbon.
* i tried both, with fantastic results..
-;ZAYED;-
