Hey guys...WTF!!
Old Jul 17, 2019 | 08:07 PM
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
Hey guys...WTF!!
I exclusively drove stripped out e46 M3s for years the sound of that i6 coupled with the exhaust was sheer driving pleasure. I decided to take the Benz for a spin and it was a completely different story. Was extremely depressing. I believe I definitely need diff bushings and I forgot I was pretending like I wasn't driving around on cracked springs....
regardless!!....
i was so so impressed with the engineering behind the way the Benz interior is put together compared to the M's but goddamn...either this is just a noisy *** fuel pump...or I cannot imagine what is going on...
only while driving which leads me to think wheel bearing but sounds like no wheel bearing I've ever heard.... please take a listen and offer any advice!!
It was was horrific I need ear plugs... not shown in video in the ****ing SCREATCH under WOT. @ 4K rpm...like wtf Mercedes.
Was so ****ing disappointed
Old Jul 18, 2019 | 09:55 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I dont think mercedes is at fault here. Sounds like there's definitely something wrong.
Old Jul 18, 2019 | 10:05 AM
BigJimmyLarge's Avatar
C204 C350 12
if you ever board google e46 cracked frame.
Old Jul 18, 2019 | 10:54 AM
PapaChop83's Avatar
2004 CLK 55 AMG, 2012 Mazda 5
Yeah that's not a normal sound - something's seriously FUBAR with that car.
Old Jul 18, 2019 | 03:34 PM
quik55's Avatar
Lol, I had 5 e46's 3 02's 1 '01 and a '06 none ever had the dreaded "subframe" issue or even signs of having been repaired by previous owners.
And also, I believe you are correct. I'm thinking it may be a sticking pad maybe? I went with Brembo pads and rotors in the rear because that's all FCP was offering at the time. I'll have to pop the caliper and check for uneven wear etc. maybe I'll bleed the brakes again, I used one of those $60 bleeders that I've never used before. When you're bleeding your brakes, you start with the one furthest from the resovoir right?? 😂
on on another note I removed the side channels from the trunk that run along the rear quarters down along the twilights to paint. I didn't put them back in and started driving to work sloshing a nice puddle in the back. Looks like they were prepared for this haha, I didn't say they weren't smart! Lucky enough to be blessed to no big deal hit the garage and switch wheels and take the '19 S4 to work. Fans dried everything by the time I got home.
Any any other opinions would be highly appreciated!!!
Old Jul 18, 2019 | 03:37 PM
PapaChop83's Avatar
Brakes were my first thought - definitely the "there's something seized up in the vicinity of a wheel" type noise, at least over the video.
Old Jul 18, 2019 | 03:44 PM
quik55's Avatar
Lmao fubar...nahh say it ain't so!! If that is the case let's consider driveshaft center bearing maybe... possible ****ty dif? I should check for a leak. Any other suggestions?
Im more worried about the horrible whistle at 35krpm and above while wide open throttle lol sounds stupid,
thanks guys!! ...always waiting for gator to chime in 😂😂
Old Jul 18, 2019 | 05:08 PM
PapaChop83's Avatar
Would check manifold/exhaust for that whistle sound.
Old Jul 18, 2019 | 06:27 PM
quik55's Avatar
Intake manifold? As in all air lines or more likely gaskets?
I believe it is the exhaust as well
Old Jul 18, 2019 | 06:52 PM
quik55's Avatar
Lol HEY Guys...
SO I'm not too cool to admit when I'm a complete idiot/possibly help other guys out LMAO!!
So...when I did my brakes and parking brake pads I was recovering from a broken neck and back. The passenger side parking brake assembly was being a real ***** so I said hmmm... when I depress the parking brake the passenger side locked up and the cable on the other side just pulled in (as to expand the parking pads) when I depressed the parking brake the passenger side spun freely and line on driver side returned to its position. Thoughts...1 is better than none. So...I only used the parking brake maybe once since then. But from my investigation it looks to be the culprit.
Grooving in backside of passenger rotor. Noise has gone away since I removed the passenger side parking brake assembly. I now no longer have a parking brake lmao!!!
Regardless... what are the chances my calipers could be bad?
Rotors do have hot spots and generally look like **** only after 10k miles. Good thing for FCP euro I guess. Other than that I think brembo pads and rotors kind of suck haha. I wonder if this could have been causing my front end slight vibration 😂😂
can't drive the car in the rain yet so I'll let you guys know once I do. I really appreciate all of your help!!!
Would still love to hear comments and opinions on why this would have happened!!
Thanks guys!
Old Jul 18, 2019 | 07:01 PM
PapaChop83's Avatar
Was thinking exhaust manifold.
