Help! Need To Replace my CLK63 Engine
Yes, all CLK63 year engines are plug n play. I see there are a lot of used C63 M156’s available on the internet; should be relatively plug n play for a qualified indy. One good thing, the stronger bolts will be on the later cars, but make sure. It’s still gonna set ya back at least $10k with labor. Keep us posted.
Yeah, I knew and I stupidly thought it wouldn't happen....hard lesson. I found a good working 2008 CLS 63 engine locally that appears identical.=C2=A0=
You're pretty close on your total cost estimate but I love my car. I'm also seeing the general value of CLK cabrios ticking upward at least here in Florida and there were only 243 total 63's imported. What are your thoughts on possible future collectability?
I would suggest that you get an engine from 2011 and later (serial number after 60658), as it has the updated headbolts and valvetrain parts.
If you buy a non-CLK engine you might need to swap the oil pan from your old one.
Good luck with your car.
https://topclassactions.com/start-a-class-action/
https://www.jacobregarlaw.com/blog/2...on-for-the-m1/
https://www.bigclassaction.com/lawsu...ngine-wear.php
It's worth some time calling the various lawyers listed in a search of internet dealing with this engine and class actions...I hope you have some luck with this terrible situation!
A $150 for the revised headbolt set? Don't think so......Try $900 plus tax, wholesale, excluding labor!
Good luck.....
Rob
Please let me know if you do front brakes soon or have any used clk63 rotors. I need the center hats
