W208 CLK55 Drive Shaft Noise at 20mph
Old Sep 19, 2021 | 12:36 AM
John76's Avatar
clk55
Hey guys,
I have a noise which appears to be coming from below the center console, possible the drive shaft. It sounds kind of like a slow garbage disposal without the high pitch sounds gargling some big chunks of bone or something like that.
It's gotten louder and more rough over the year or so. I hear it only when I hit around 20mhp, slower acceleration seems to bring it out more. Below or above 20mph it's goes away.. Doesn't always come on unless I hit the sweet spot somehow when attempting make it sound. On the freeway it comes on also when holding the gas steady and/or not accelerating too fast.s
Any ideas? Some loose bolts maybe?
Old Sep 19, 2021 | 01:37 PM
MattCordell's Avatar
C43 AMG with a tune up
Could either be your center bearing or one of the two donuts on driveshaft?
What's the mileage?
Old Sep 19, 2021 | 02:58 PM
John76's Avatar
clk55
What's the mileage?
It has about 165k miles on it.
Can it be inspected from beneath or would one have to remove parts to inspect?
How many hours do you estimate for a mechanic to fix either of those issues? Wondering if it’s a pretty straight forward job to DIY or leave it for the experts?
tia
Old Sep 20, 2021 | 10:57 AM
Put the car on a hoist and check for play.
Your rubber donuts might have cracks from old age?
It will take a few hours to do the job.
If you're skilled you can do it yourself otherwise take your car to a reputable shop.
Old Sep 20, 2021 | 12:25 PM
John76's Avatar
clk55
Ah ok thanks.
Old Sep 20, 2021 | 12:35 PM
John76's Avatar
clk55
Is this what your talking about for the donuts? front and rear..
https://www.rockauto.com/en/moreinfo...pt=10701&jsn=8
And center bearings?
https://www.rockauto.com/en/moreinfo...t=12743&jsn=12
Old Sep 20, 2021 | 12:52 PM
Donuts keeps the drive shaft in balance and removes vibrations so does the center bearing.
Don't buy no-name parts, buy only known branded parts like OE or OEM!
Buy genuine MB parts or Lemfoerder aftermarket parts
Happy driving
Old Sep 20, 2021 | 02:06 PM
John76's Avatar
clk55
Happy driving
Thanks again.
Old Sep 21, 2021 | 10:32 AM
breeze247's Avatar
W209 CLK55 - 2003
I have a thread somewhere here that shows the centre bearing noise I was hearing.
Worth looking at that thread and watching the video to compare.
All of my issues went away after replacing the centre bearing, bearing carrier and both prop shaft rubber flex joints.
Old Sep 21, 2021 | 11:42 AM
John76's Avatar
clk55
Hey Thanks. Just saw the video, and read through your post, the noise doesn't sound exactly like mine but everything else sounds like it. low speed, intermittent, usually on low acceleration. I think it's the most likely culprit. When you say bearing and carrier, that part is sold as one piece correct, not two? The two parts I listed up there, is what I would only need correct? Curious how much did it cost you to fix?
Old Sep 21, 2021 | 01:19 PM
breeze247's Avatar
W209 CLK55 - 2003
When buying from the dealer, the carrier and bearing are two different parts. Aftermarket often does them together. I bought dealer bearing and carrier and two Lemforder donuts. I’d recommend dealer or quality OEM, don’t buy cheap parts.
I paid around £450 in total (I am based in the UK). I suspect could have saved £75 or so shopping around for labour. They said that it would have been cheaper if I replaced the bearing but not the donuts.
The reason I waited so long is because a shop actually checked and told me the bearing was fine. Glad to have replaced it.
Old Sep 27, 2021 | 03:47 PM
John76's Avatar
clk55
Hey there, do you know if we need to remove the exhaust replace these parts?
Old Sep 27, 2021 | 05:45 PM
breeze247's Avatar
W209 CLK55 - 2003
Yes. I wouldn’t attempt it without a lift.
