2003 clk55 amg
Old Apr 15, 2024 | 09:17 PM
TerryMcAllister's Avatar
clk 55 amg
2003 clk55 amg
New member 2003 clk 55 amg with oil pressure warning light comes on after 15 miles on free way at 70 75 mph. Says I have to much pressure. Drop down to 60 mph goes off. The auto has no oil dip stick. So I had oil changed with new filter and new oil pressure sensor. Same deal should I drain some oil and see. The oil change place is very reputable place. Nothing shows up on digital plug in. and the the oil check on the screen says oil is fine. Any body else run into this problem before ? I'm afraid to get on freeway. Terry McAllister
Old Apr 16, 2024 | 01:42 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W209 AMG forum...
Old Apr 16, 2024 | 06:31 AM
PHILLYCLSJOE's Avatar
2002 CLK55 AMG: 2004 S55 AMG: 2009 C63
Great looking car Terry.
I would suggest getting a good shop to hook it up to a scanner and see if they can pull any hard stored codes, or something you're not seeing that could be causing the issue.
Tell them to check the wiring thats leading to the sensor, its possible there is a bad ground somewhere or vibration is causing a short at higher speeds, throwing the light.
Check your breather hoses and make sure they aren't clogged up as that could be building pressure as well. (Top of Driver side valve cover leading towards back of motor and into throttle body) Make sure all of your Vacuum lines and breather hoses are in good shape. It's common on M113 cars for these to crack and become brittle over time.
Hows the service history? When was the last time it had a full tune up, Plugs, Coils, Wires, Valve cover Gaskets, Motor mounts, Etc?
Lastly, and i would assume most unlikely, another oil pressure sensor switch, however i doubt you have 2 bad units. I would suggest purchasing all of your parts through FCPEuro moving forward as they have lifetime warranty's on everything.
Good luck and report back
- Joe
Old Apr 16, 2024 | 06:11 PM
clk 55 amg
Thumbs up
Thanks Joe Ill do the research you suggested. Terry
Old Apr 19, 2024 | 06:05 AM
Sandygear's Avatar
2004 e500
These cars don't have engine oil pressure sensors. They do have engine oil level sensors. And I don't think they display errors for low transmission oil pressure.
