suspension adjustments
The one thing I plan on doing for the street is increasing the rebound. It's a bit soft for my taste and I feel on some big dips the car tends to float after the first stage of compression. Other than that, there really is no end to how well you can tune this cars suspension. Hope that helps.
Have you been to the big track? The BS would likely just eat the ground between 6 and 9 like a monster.
What groups to you track with? Would love to come out for a ride next time you go out.
When you went to 55 psi what was your "cold" starting point? I know I always have to bleed out air and by the end of the day the cold tire pressures are in the high 20's.
I was shocked to see that MB put the psi ratings for the BS as a reverse stagger . That is what I have always run on a C32.
Corsa's gained a reputation of chunking, any indication of that. Secondly, were the 35/38 psi a wild guess or did you work down to those pressures.
I'm tracking my car next week and appreciate your input.
Jimmy
I wasn't really planning on doing much track time, so I didn't take tire temps before my first session. Then as soon as I got out there it was all over, and I realized I needed to come in and make a few adjustments if I really wanted to push it. So, needless to say, I was shocked when I saw 55psi and immediately backed it off to where I thought it should be. It made a big difference. But to be perfectly honest, and this was discussed in my track thread previously, the temps combined with the altitude were brutal that day. I was standing on it exiting turns with very little to no wheel spin. If I had done that tonight, temp is 60, in 1st or 2nd, the thing would have been WAY sideways. So, on a cold winter morning at willow, I think I could have shaved at least 2-3 seconds off...maybe more if I wanted to be stupid. But I really like this car and dropping a wheel at willow would be ugly...
The corsa's are.....ok. They performed very very well on the track, but as Jim stated, they chunked quite a bit and since both tracks at willow kill the front left - my car now steers a bit right. My corsa's are fine for the street after all that, but I wouldn't run them much more on the track. I think I'll be putting some MPSC's on as soon as these are gone. And that wont be long...
Jim - I had some pretty good race guys with me ( the crew) and they suggested going straight to 35/38. It made a big difference and the car really just grabbed, hunkered down and ate the big track up. Because of the weight, it had a harder time on streets. As Cyn correctly suggested, the car was a friggin monster from 6-9 on the big track. I was exiting 9 at about 120 to give you and idea of how much speed it will carry. But, and this is a big but....you really have to push it through 7 and 8 and be on the power, no lifting whatsoever. I did lift through there once with the track control on and it saved my ***. I did this simply to see how aggressive the black series ESP is written and how well it could save a novice driver. It worked well to say the least.
Enjoy your cars guys, and Jim, have fun out there and be safe. I'll be interested to hear your impressions next week.
Thank you for the input on tire pressures. 1:30 !!!. For those on the board not familiar with Big Willow, that is serious fast for a street car. I don't think any of the glossy fish wraps got close to that number in a Ford GT or Z06.
One last question, does the car need a wing (more down force0 in turn 8?
But that car is 800 pound lighter remember.
A 1:30 is insane for that CLK I never thought it would be that quick.
The time at the big track is much more understandable. I run a 1:34 in a C32 with many mods so low 1:30's for the CLK BS makes sense. A well driven lotus elise is a 1:31 second car at the big track and a Z-06 also is in that company.
Anything in the low 1:30's is amazing for a street car weighing in at 3800 pounds without a driver in the car.
These were easy. One click in front elimated my looseness in rear braking. The KW has so much more adjustability then just about anything out there.
I believe you get twice as much range as the PSS 9s.
Jimmy
