CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Paddle shifter update kit
Old Sep 16, 2008 | 07:06 PM
Jim Brady's Avatar
'22 G 63 AMG, '21 GLE 53 AMG, '20 NSX
I recently noticed that my right up shift paddle was not upshifting and appeared to be loose. Others have reported the problem. Apperently it is more wide spread than I thought as there is an updated repair kit to fix this glitch. Just wanted to let the board know.
Jimmy
Old Sep 16, 2008 | 07:23 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Thanks Jimmy - I'll keep an eye out although mine seem ok thus far and I only drive my car in M so they get quite a workout
Old Sep 16, 2008 | 11:50 PM
Jim Brady's Avatar
I wanted to add, if your upshifts and downshifts are slow, good chance you need the updated paddles.
Jimmy
Old Sep 17, 2008 | 03:07 AM
JDB's Avatar
JDB
CLK63 Black Series
Hi Jimmy,
Do you have any more specific details regarding the updated paddle shifters, such as part numbers or a bulletin?
JDB
Old Sep 17, 2008 | 03:15 PM
LZH's Avatar
LZH
Jimmy
Well that changes things a bit. My upshifts are neck snapping quick but the down shifts are very slow. You think this is normal ?
Old Sep 17, 2008 | 11:37 PM
Jim Brady's Avatar
Originally Posted by JDB
Hi Jimmy,
JDB
Part number 171-267-00-46 Rocker Switch.
Test to determine 541011, Perform 5225 W67.
Repair order says "Removed and replaced right and left paddle shifters with Updated Repair Kit.
Repair requires removing air bag. Be sure and remove battery ground before removing air bag. If you try this at home.
Jimmy
Old Sep 17, 2008 | 11:43 PM
JDB's Avatar
JDB
CLK63 Black Series
With the car stopped, and the engine off, take a look at the backside of your steering wheel and look at how the paddle shifters are mounted into the wheel. On my car, it was very obvious that the mounting was broken, because the paddle shifter assembly seemed loose in the steering wheel.
The symptom that first made me question that there might be a problem was that I began to notice that my car would not upshift when I would pull on the upshift paddle. Downshifts were fine. At first I noticed that, it would upshift, but irregularly. Sometimes it would upshift, then other times it took several tries on the shifter paddle to get the shift to occur. (Reminded me of bad contacts on an electric window switch). I found that if I used the center console gear selector to manually shift the car, the upshifts were precise and immediate, as you would normally expect.
The problem was easily fixed. The dealer ordered a new set of paddles and switches and the replacement only took a couple of minutes. By the way, it turned out that both switches were failing. Both had cracks running across the area where the screw draws the switch assembly into the steering wheel.
JDB
Old Sep 17, 2008 | 11:59 PM
Jim Brady's Avatar
LZH,
Check your gear selector lever position indicator for the gear range that appears in the odometer desplay. When downshifting, the gear change indicator number should be immediate. If the indicator isn't immediate then your downshift paddle isn't working correctly. If your downshifts are slow, your transmission ecu isn't getting the signal to downshift or it doesn't want to do something stupid like going from 100mph into 2nd gear.
Jimmy
Old Sep 18, 2008 | 12:02 AM
JDB's Avatar
JDB
CLK63 Black Series
Jimmy
Hi Jimmy,
Thanks for the details.
JDB
Old Sep 23, 2008 | 04:50 PM
LZH's Avatar
LZH
Likewise - thank you both for the info, much appreciated.
Old Jul 15, 2009 | 04:57 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Jimmy
I'm sorry to revive such an old thread, but I have the BS steering on my E63, and I started having the exact same problem as you described: my right paddle shifter would not upshift sometimes and feels sluggish. My downshift paddle works perfectly everytime
Did the updated kit fix the problem permenantly? Did the problem ever return?
Old Jul 15, 2009 | 05:16 PM
MMC2488's Avatar
CLK 63 AMG Black Series
On my second set of paddles. Hope these break so I can get the updated ones.
Old Jul 15, 2009 | 06:22 PM
toddturbos's Avatar
2008 MB CLK Black Series
Thanks for the information, mine has always been slow when downshifting, upshifting is very quick.
Todd
Old Jul 16, 2009 | 05:17 PM
Eitan1's Avatar
WHT BS
Mine is also quick on the upshift and slow on the downshift. I think this has nothing to do with the paddles, and everything to do with the actual ecu / tcu tuning from the factory.
Old Jul 16, 2009 | 09:17 PM
LZH's Avatar
LZH
Exactly - and the way to test if the paddles are not working properly is to use the gearshift and see if there is any difference.
If we could just get that damn Speedshift Plus software....
Old Jul 17, 2009 | 02:49 PM
spr's Avatar
spr
Why not just flash with c63 tcu soft?? Should work just fine no? then you get the blip.
Old Jul 17, 2009 | 03:48 PM
DFW01E55's Avatar
'14 ML BT
The C63 ECU is also de-tuned by 50hp or so compared to the BS.
Old Jul 17, 2009 | 03:55 PM
spr's Avatar
spr
Tcu not ecu. Unless they are somehow together now. My understanding is that they are seperate units- hence the flashing of TCU v. ECU. For this reason I want to flash my tcu for instance with the clkdtm prog as it is the "M1" prog with lighting shifts.
Old Jul 17, 2009 | 04:15 PM
DFW01E55's Avatar
'14 ML BT
DOH!
You did say TCU, my mistake.
Any possibility of that flash happening?
Old Jul 17, 2009 | 04:32 PM
spr's Avatar
spr
Hehe np. Yeah I don't see why not right? This is a backdoor way of getting what you guys want when MB won't. I would believe that the modules are the same and 7g trannys as well such that there is no difference whatsoever in doing so it's just a simple flash. Just find a master mechanic you can throw a couple of cigars at
Old Jul 17, 2009 | 06:34 PM
LZH's Avatar
LZH
Not possible guys as the TCU and ECU are both VIN specific. I've been bangin my head against a wall over this crap for a year now...
Old Jul 17, 2009 | 07:40 PM
spr's Avatar
spr
Is that because the MB STAR computer won't let you do it or what? Usually software isn't too much of an issue. If so, a work around would be to swap in the tcu from a c63 with the flash already on it no??
Old Jul 17, 2009 | 07:52 PM
LZH's Avatar
LZH
It's because the newer Speedshift Plus ECUs and TCUs will only mate with cars that have corresponding VINs. If you tried to code a Speedshift Plus ECU or TCU to a BS it wouldn't work. If you were to try something like this, the newer CLS63 ECU/TCU would be the way to go. It would require taking them out of a CLS and then coding them ia STAR to accept a BS VIN. Or something like that...I've been round and round on this topic and Powerchip was going to help if we could get doner ECUs as a starting point...
Old Jul 17, 2009 | 07:57 PM
kiamcoj's Avatar
2012 CLS63
Anybody have some broken/spare paddles that they want to let go of? I need some to play around with for an upcoming project. Please PM me if you want to help a lower class CLK driver out . Thanks!
Jon
Old Jul 28, 2011 | 08:28 AM
rage2's Avatar
C63 BS, GLA45
Here's what a broken downshift paddle looks like. I had mine replaced under warranty a few weeks ago, and got to take pics of the broken piece. Shifts are instant once the piece is replaced with the updated piece that's stronger.
