CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Dif Leak
Old May 23, 2009 | 11:03 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Dif Leak
Wondering if any of you guys have had this prob...I'm pretty sure it's not a leak or a blown seal, although I need to get it on a lift to see. I've got dif fluid dripping on the exhaust as the exhaust runs right next to it (right side). I know there is an overflow hole at the top of the dif and I'm pretty sure that's where it's coming from as it did it once before last time the fluid was changed - but, it's been months since I had the fluid changed. The overflow is also there if the fluid gets too hot it'll come out there. But yesterday I smelled burning (fluid hitting hot exhaust/small amount of white smoke) and checked it out and sure enough I could see a slight drip.
Anyone else every have this happen ? I'm not too worried...if the dif does destroy itself I get a new one under warranty
Old May 23, 2009 | 11:36 PM
DFW01E55's Avatar
'14 ML BT
Thankfully I haven't seen that.
If you toast it maybe you can get them to install a Quaife.
Maybe not.
Old May 24, 2009 | 12:48 AM
Jim Brady's Avatar
'22 G 63 AMG, '21 GLE 53 AMG, '20 NSX
Luke,
I think JDB had the same problem. I've seen it on the track in Germany and it turned out to be a diff oil cooler line which was blown on the hot exhaust.
I've also seen a "holed" oil cooler from a rock that caued the same issue you discribe.
Old May 24, 2009 | 01:20 AM
Frankster's Avatar
keep us posted. Was it recently serviced?
Old May 24, 2009 | 06:41 AM
JDB's Avatar
JDB
CLK63 Black Series
Originally Posted by Jim Brady
Luke,
Jim,
Regarding my prior posting. I noticed an odor of what I believed to be the smell of heated differential oil whenever I drive the car a little harder than I normally do. I took the car to the dealership and the shop foreman and I thoroughly inspected the underside of the car, while it was up on a lift.
We couldn't find any evidence of any leaking fluids, anywhere. The next time we have it up in the air, I will double check the exhaust system to see if there is any evidence discoloration from fluid, but right now, I think that all that I was noticing was the smell of the fluid being warmed up a little more than what is normal for my car.
I'll post more, if I learn more.
JDB
Old May 24, 2009 | 03:07 PM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
Luke-
Were you romping on the car or cruising it? The overflow is also there to let any built up pressure when you are spinning the rear in high RPM runs. Possibly aeration?
A lift should answer your questions immediately. Let us know what you find!
Old May 24, 2009 | 04:32 PM
LZH's Avatar
LZH
Thanks guys - I've done the best "visual" that I can without a lift. All the cooler lines seem to be intact. My last service was almost a year ago so the overfilled dif scenario isn't really a concern.
TT could be right, but when this happened I wasn't driving it hard at all...I guess gettin'er on a lift needs to happen sooner rather than later.
I'll keep you guys posted.
Old May 27, 2009 | 07:44 PM
LZH's Avatar
LZH
Well I went by the shop today and we put'er up on the lift...no leak, just seemes to be a bit of seepage coming from the top overflow hole. The entire right side of the dif was however wet so we cleaned it off and I guess I'll just keep an eye on it as per the shop foremans instructions.
Just thought I'd fill you guys in....
Old May 27, 2009 | 08:03 PM
DFW01E55's Avatar
'14 ML BT
Thanks, I'll check mine in the next few days and let you know if it's a match.
Old May 27, 2009 | 08:19 PM
LZH's Avatar
LZH
U bet, although if yours is/was doing the same....you'd smell it pretty quickly.
Old Jun 11, 2009 | 11:16 AM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Luke, mine started leaking that day we were at Willow in January. It was indeed the seal and not an overflow. If I recall it took several days to obtain the part because they were on back order and it had to come out of Germany.
Old Jun 11, 2009 | 03:10 PM
LZH's Avatar
LZH
Thanks Jim....We poked around mine when it was on the lift and it was pretty apparent it was coming from the overflow valve. Strange....
Old Jun 17, 2009 | 09:53 AM
DFW01E55's Avatar
'14 ML BT
Checked mine last night, same thing, Not an active leak, just overflow seepage.
Old Jun 17, 2009 | 03:21 PM
LZH's Avatar
LZH
That's good to know. Was the passanger side of your diff all wet ? Mine was and the drivers side was dry...
Old Jun 17, 2009 | 03:37 PM
DFW01E55's Avatar
'14 ML BT
It was only the passenger side but it was just oil covered with dirt/dust.
Old Jun 17, 2009 | 03:43 PM
LZH's Avatar
LZH
Thanks for the info. Sounds like this is normal for these cars.
Old Sep 8, 2011 | 12:14 AM
isellbenz's Avatar
2005 C230WZ, 2004 E55, 2004 Audi S4
My E55 is doing this very same thing... Anything ever come of it?
