CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Question - K&N Filter Installation
Old Jun 5, 2009 | 02:39 PM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
Has anyone installed K&N filters in the CLKBS yet? I tried it today but I'm not not mechanically inclined and could not get the covers off after removing the four hex screws on each side. Is there a hidden hex screw and must I also remove the intake tubes? It was a lot easier on my other AMG's.
Old Jun 5, 2009 | 03:43 PM
SMP's Avatar
SMP
CLK63 Black Series
As far as I recall, there are 6 hex screws on each side. One, I think is under the strut tower brace. Instead of going with the K&N filters, I recommend the BMC filters. That's what I have in my car.
Attached Thumbnails Question - K&N Filter Installation-dscn1867.jpg   Question - K&N Filter Installation-dscn1883.jpg
Old Jun 5, 2009 | 03:44 PM
ET550's Avatar
2008 CLK 63 Black Series, 2013 G63, 2014 RS5 Coupe, 2013 JKUR 10A
I seem to recall there was a thread last year showing step by step photos of how to remove the air filters and air box (and mention of a hidden screw) but can't seem to find it using the search feature at the moment. Maybe someone else remembers.
Old Jun 5, 2009 | 04:01 PM
LOVEMYBS's Avatar
Replaced My Filters
After talking to my local SA who looked at the replacement procedures I was able to replace my OEM filters with K&Ns. It's not difficult.
1. Requires 2 K&N 33-2405 filters that cost approximately $50.00 a piece.
2. Pull up and unsnap the front part of the "U" cover. It's tight and held by three snaps (front and two sides) but it will come loose.
3. Find the correct torx screwdriver to unscrew the FIVE (5) torx screws that hold the air filter cover down
4. Lift the cover and remove the OEM air filter. I also used my ShopVac to clean the inside of the filter housing (although I only have 7,900 miles there was still a lot of dirt and leaves)
5. Replace with K&N filter, it slides right in.
6. Replace screws and tighten.
7. Snap the "U" cover back into place
It took me about 30 minutes to replace both air filters.
Old Jun 5, 2009 | 04:15 PM
toddturbos's Avatar
2008 MB CLK Black Series
SMP, love the CF cover, where did you purchase and how much?
Todd
Old Jun 5, 2009 | 04:28 PM
SMP's Avatar
SMP
CLK63 Black Series
Todd
Todd, I bought it from Victor at VRP. I think the company that produces the cover is called Carbonium. I bought the cover a long time ago, for somewhere around $2000 and put it on myself. The cover might be cheaper now.
Sascha
Old Jun 5, 2009 | 05:52 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
You forgot between 5 and 6...remove charcoal filters and toss in trash.
Old Jun 5, 2009 | 05:55 PM
Akademiks's Avatar
SL600
The picture of your engine cover is amazing! Very nice.
Old Jun 5, 2009 | 07:36 PM
mpounias's Avatar
CLK63amg Black Series
Hi,
Do you know what the gains are with the BMC filter installed????
Old Jun 5, 2009 | 08:09 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
Originally Posted by mpounias
Hi,
3-6rwhp, varies
Old Jun 5, 2009 | 08:11 PM
mpounias's Avatar
Thanks a lot i might try them.
One more question do i have to do some other mods or they will work fine with a stock BS?
Old Jun 5, 2009 | 08:14 PM
SMP's Avatar
SMP
CLK63 Black Series
Hi,
My CF airbox has a bigger plenum compared to the stock one. That in combination of removing the charcoal filters/paper filters and putting in BMC's will make some power. Can't say what it would translate into hp numbers on a dyno though.
Old Jun 6, 2009 | 10:09 AM
GeoGeo's Avatar
CLK BS
Any issues with CEL?
Old Jun 6, 2009 | 10:28 AM
ohlord's Avatar
Here we go again
stock filters out flow K/N so why are you robbing your car of Power?
let the games begin
Old Jun 6, 2009 | 12:13 PM
SMP's Avatar
SMP
CLK63 Black Series
No CEL issues. The oil that is used on the BMC filters has been tested and has no effect on the MAF elements. Also, the polyurethane edge of the filters will not break or de-compose like other brands from under-hood heat. I've been using BMC's for years and they are also used in Formula 1 cars. That comes with a premium of course, filters are twice as expensive as K&N's.
Old Jun 7, 2009 | 04:19 AM
Frankster's Avatar
any dyno comparisons between the 2 brands?
