CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Lowered BS
Old Jul 29, 2010 | 10:23 AM
360racer's Avatar
Clk63 Black Series
Lowered BS
Anyone here wind down their BS suspension? If so any pics of it lowered all the way down ?
Old Jul 29, 2010 | 01:32 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
For the street or are you going to track your car ?
If it's to get a certain "look" for the street, you may end up with a bit of damage....
Old Jul 30, 2010 | 05:03 AM
360racer's Avatar
Clk63 Black Series
street car
Old Jul 30, 2010 | 09:31 AM
RBYCC's Avatar
street car
You could "slam" it, but with no benefit to street performance.
Always potential damage on speed bumps, dips, pot holes, curbs, inclined driveways, parking lot bumpers and so many more things you run across in daily driving...
Old Jul 30, 2010 | 09:52 AM
cigarette1's Avatar
Or, you can lower it with a set of springs and have no problems what so ever.
G
Old Jul 30, 2010 | 02:25 PM
RBYCC's Avatar
G
OP just wanted to play with the coilovers....
Old Jul 30, 2010 | 03:32 PM
cigarette1's Avatar
Got it
Old Jul 30, 2010 | 04:55 PM
SMP's Avatar
SMP
CLK63 Black Series
All that playing comes to an abrupt halt after about 1/2 an inch .......... than you need springs
Old Jul 30, 2010 | 06:41 PM
mellowyellow's Avatar
AMG GT C Roadster
Is the factory standard front height supposed to be higher than the rear? I know it helps for curbs and driveways/etc, but mine probably needs to drop another 3-5mm in the front. The rear looks great.
I need to see if I can measure the adjusting ring height compared to factory settings (front is supposed to be 1.1 inch from the adjusting ring to the mark).
Old Jul 30, 2010 | 07:20 PM
SMP's Avatar
SMP
CLK63 Black Series
No, it's not suppose to be higher than the rear. Driver side front is a touch higher, but the other 3 corners are the same. Most likely it's just an optical illusion because of the fender flares. When ride height is changed and the car is getting properly aligned, the shop has either someone sitting in the driver seat or putting some weight there instead while everything is getting adjusted.
