CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Black Series Intake / Air Inlet
Old Dec 9, 2010 | 05:57 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
I was poking around under my hood and noticed that the air inlets for the intake are blocked by a small piece of plastic that prevents air from going straight into the intake tubes. I presume this is to prevent rain and other debris from making it's way up the intake path into the filters. It would seem to me that if these small pieces were removed it would create more of a ram air effect allowing better airflow into the motor. What do you guys think? Or, would additional/more forceful airflow be negated by the fact that our throttles never open all the way ? I look forward to your thoughts.
Attached Thumbnails Black Series Intake / Air Inlet-intake1.jpg   Black Series Intake / Air Inlet-intake2.jpg
Old Dec 9, 2010 | 06:10 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
I'm sure it design to prevent water enter when rain. Here's 2 pics of my cars. The CL 55 air inlet is also cover but the CLK 500 air inlet is completely open.
Attached Thumbnails Black Series Intake / Air Inlet-user78142_pic3612_1236485715.jpg   Black Series Intake / Air Inlet-pb180091.jpg
Old Dec 9, 2010 | 06:20 PM
LZH's Avatar
LZH
Thanks for the pix...yeah that IS odd
I just don't know...I would think that moisture is the only reason for it as the filter would take care of any debris. Also, any water that might enter would be evaporated by the heat in the intake tubes...then the condensation might pose an issue/problem. But the fact that your CLK 500 is wide open leads me to believe that I'm just overthinking it and being overly cautious...
Old Dec 9, 2010 | 06:41 PM
Jim Brady's Avatar
'22 G 63 AMG, '21 GLE 53 AMG, '20 NSX
I removed the obstructions only to find that sand finds it way into the filter system much easier. I abanonded further home modificaitons
Old Dec 9, 2010 | 07:06 PM
LZH's Avatar
LZH
Jimmy - so did you have to buy new pieces and install them after you cut the other pieces up?
Old Dec 11, 2010 | 05:04 PM
Jim Brady's Avatar
Yes had evosport do a little internal work on the new one.
Old Dec 11, 2010 | 07:01 PM
LZH's Avatar
LZH
Care to share exactly what they did ?
Old Dec 12, 2010 | 11:51 AM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
e
Mine are removed as well as some internal mods done by evesport, I have not had any issues with the intake tube the more free floningwing openings, at least nothing an air filter can't stop. Have any of you guys taken a good look at the intake openings onan SLS? You can put your fist into the openings and its a straight shot into filters and MAF, they don't seem too concerned about debris with that set up right out of the factory.
Luke...you catch a case of the modding bug lately?
Old Dec 12, 2010 | 12:22 PM
Jim Brady's Avatar
Evosport did some internal mods to the air box, hard to say how much improvment but with these motors a little here and a little there seems to add up. Still, it seems that the big improvement comes with long tube headers and exhaust. That's difficult in Calif. as that's a fail on the smog test.
Old Dec 20, 2010 | 12:29 AM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
Not to jump in, but very similar plastic shields came in my GL (snap-in versus molded piece). I removed them without problem and have since put around 3k miles on without any noticeable issues.
Old Dec 20, 2010 | 02:34 AM
badblackbenz550's Avatar
benzo larenzo
My CLK 550 just has ram air like klinh posted, when my car goes in to handless car wash with high pressured water and air drier my car stalls engine just shuts off and i cant start it untill the driers or water stops.
Old Dec 20, 2010 | 02:41 AM
This actually reminds me that my C63 stalled a couple times in a high pressure wash. The only mods I had on that car were a tune & a charcoal delete (I didn't modify the intake at all).
Old Dec 20, 2010 | 02:49 AM
benzo larenzo
My intake is totaly stock and has 0 restrictions now this conforms that my car is not electrically messed up =D
Old Dec 20, 2010 | 02:53 AM
Or both of ours might be messed up!
Old Dec 20, 2010 | 08:34 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
What car wash do you go to?
Old Dec 20, 2010 | 12:20 PM
benzo larenzo
when im lazy i go to one in Hackensack the one that says touch less it just sprays your car with high pressured water, it only takes off top layer of dirt lol.
But yeah every time im in there i shut my car off and then right before the wind comes i pull my scar up front slowly so the insate dont suck it in.
Old Dec 20, 2010 | 01:02 PM
black-clk500's Avatar
'14 911S (garage queen) '13 X3 (family hauler)
No, they just want a proper handwash
Just be happy, to get even, they don't punch you in the face with the airbag.
Old Dec 20, 2010 | 01:55 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
lol, that's a good one.
Old Dec 26, 2010 | 03:34 AM
Sincity's Avatar
Evosport did some internal mods to the air box, .
+2. What did Evosport do? I've heard (hearsay) before that they drilled holes to the bottom of each intake box.
