M156 Engine Class Action Suit
https://mbworld.org/forums/c63-amg-w...ne-issues.html
http://www.benzbost.com/content.php?...engine-defects
put another o in 'bost'
does this effect the BS?
If this turns out to be an actual defect, let's hope MB/AMG remedies it and extends the engine warranty.
+1 .... lot of jibberish noise ... 99% of it is completely unsubstantiated. Enjoy your 6.3L and rev it to hell and back. You will be fine
Issue 1: These engines take 0w-40 synthetic oil from the factory. If you have the dealership change your oil they put 5w-40 synthetic oil. Although MB isn't admitting any type of guilt here, they have obviously learned to change the oil. The reason for this is because the lifters are known to bleed the oil out when the camshaft is in the correct position overnight or for a few days pressing against the lifter. When someone starts the car the next day you get the lifter tick which many people have complained about. If this happens enough times, it will cause an issue, and this can perhaps be the reasoning behind this.
Issue 2: When replacing or simply removing camshafts the lifter will expand from the pressure. The problem with this is the fact that simply installing the camshaft can be a problem now because the lifter will now hang the valve open for a while, and it is a possibility that if can bind the valve spring putting unwanted pressure on the camshaft, lifter, valves, etc. Now these are 1 out of a million chances of causing serious damage, but again it is possible.
Issue 3: As someone stated earlier, the lifter is very flat where it meets the camshaft lobe. This is a little odd in design because the lifter needs to have some kind of ability to spin in its bore during its motion. It might have been beneficial to give it a dome like shape.
Lastly, just an FYI for guys running the M156/M159 engine. If you haven't driven the car in a few days and you hear an kind of valve train noise, do not drive the car. Let it idle till the noise goes away. Also put 5w-40 in the engine if you haven't yet. Thanks.
Steve
Weistec Engineering
