CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Need help figuring out Aspect Ratio
Old Apr 16, 2013 | 04:40 PM
Eitan's Avatar
CLk Black
Hello All,
Does anyone know if a 255/35/19 tire will work on the fronts of the black series? Can anyone tell me what the stock 265/30/19 aspect ratio would be compared to a 255/35/19 or 255/30/19? Your help and expertise is much appreciated.
Thank you,
Eitan
Old Apr 16, 2013 | 04:50 PM
sprins's Avatar
G55, SLS, smart eq
Does this site answer your question? http://www.tyresizecalculator.com/
Old Apr 16, 2013 | 05:08 PM
NYC_Z06's Avatar
CLK63 BS
http://www.tirerack.com/tires/tirete...e.jsp?techid=7
Old Apr 16, 2013 | 07:59 PM
ET550's Avatar
2008 CLK 63 Black Series, 2013 G63, 2014 RS5 Coupe, 2013 JKUR 10A
Try this site if you want to compare tire sizes and see if there are any obvious clearance issues:
http://www.rimsntires.com/specs.jsp
Old Apr 17, 2013 | 06:00 PM
Eitan's Avatar
CLk Black
Thank you for all the responses. After doing some research, i found out that neither set up will work for the front as the 255/35 is too tall, and the 255/30 is too short comapred to the stock 265/30. I believe that i have finally found a set of tires that are made in the correct sizes and are not Crappy like the Yokohama Advans, Hankook Ventus, and the continental DWS, and are not ridiculously expensive like the Pirelli Corsas. I should have my new tires very soon. I will let you all know how they are.
Thanks again,
Eitan
Old Apr 18, 2013 | 11:24 AM
NYC_Z06's Avatar
CLK63 BS
Regular Michelin Pilot Sports (non cups) and regular Pirelli PZeros (non Corsa) are available if you go to a 265/35/19 in the front. That's what I have on my BS.
Old Apr 18, 2013 | 03:47 PM
Eitan's Avatar
CLk Black
Thank you for the information. the 265/35/10 are taller than the stock fronts. I am not sure if this is going to create any problems with the TC and cause the car to shoot a fualt. Have you experienced any issues of this kind in the time youve used the 265/25 in the front?
Old Apr 18, 2013 | 04:16 PM
NYC_Z06's Avatar
CLK63 BS
No faults. Park Place MB replaced the tires prior to my purchase with the Pirellis. The the front side walls do not appear taller than the rears. Mind you, there are owners who have gone way out from normal spec w/o issue.
