CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Stock wheel setup - 20mm spacers?
Old May 18, 2014 | 09:35 AM
Jcrame00's Avatar
CLK63 BS, 996 Turbo, Lexus ES300h
I've been through all posts related to wheel spacers and have pm'd a few of you regarding spacer sizes on a stock wheel set-up. Seems most are running 10mm to 12mm.
Is anyone running north of 12mm? There is youtube clip showing a BS with 20mm's (before/after views). Do you see any downside for use of 20mm for street use only on BS with stock suspension?
Last edited by Jcrame00; May 18, 2014 at 09:42 AM. Reason: Clarification of details
Old May 20, 2014 | 08:03 PM
Infamouz's Avatar
C204, W209, W164
Get good quality spacers and remember you need new bolts according to what you're increasing it by.
I have 12mm front, 20mm rear. Even with 20mm rear, the rims still aren't perfectly flush.
Old May 22, 2014 | 05:13 AM
1JDM911's Avatar
'12 C63BS "SlickTop", '08 CLK63BS, '16 E63S wagon, '12 CLS63, amongst other non-Merc toys
go with H&R, their setup for our car is perfect.
Old May 22, 2014 | 08:06 AM
Jcrame00's Avatar
Are you running stock wheels with your set-up?
Old May 22, 2014 | 08:08 AM
Jcrame00's Avatar
Okay. What size spacers do you have front and back and do you have stock wheels? Thx
Old May 23, 2014 | 04:26 AM
1JDM911's Avatar
10mm/12mm, longer studs, genuine AMG wheels by Alcoa's Forged light weight aluminum.
Old Feb 10, 2015 | 02:23 PM
neo9080's Avatar
2012 c250 sport, amg 18 wheels, H&R sport, nav, 12mm rear 15 front spacers, Godhand front splitter
i have a stock c250 with 18s. running 12 front and 20 rear. perfect. no springs, and a little bit of rubbing in the back over dips while turning, but nothing crazy.
Old Apr 22, 2015 | 07:20 PM
mark j's Avatar
2008 clk63 bs
does anyone have part numbers for a 2008 clk63 bs 10mm front and 12 mm rear? h&r doenst have the car listed on the website and i have not been able to get a call back from them?
Old Apr 23, 2015 | 12:28 PM
NYC_Z06's Avatar
CLK63 BS
Try RAD OTIS. That's where I picked up my spacers and extended bolts.
Old Apr 23, 2015 | 09:51 PM
Heisman_'s Avatar
2007 C230 Sport
I have a C230 and Just bought the same exact AMG Rims. Are you happy with that spacer size? or would you go bigger/smaller if you were to do it again?
Also what was the specs on the Wheel Studs you used? I don't think stock wheel Studs work.
also those wheels look great
Old Apr 24, 2015 | 08:04 AM
shellx's Avatar
2008 CLK63 Black Series
Does anyone know the exact extended bolt length/type to order from RAD for 10mm and 12mm spacers? Are they ball seat or cone?
Thanks!
Old Apr 27, 2015 | 02:22 PM
COOPERDB's Avatar
NB8 PARACHUTE
I just got off the phone with a tech at H&R
He said that H&R did not make spacers for
the CLK63 Black Series because only
350 CLK63 Black Series were produced
But - Looking at the application chart
I see that they have spacers for a 2009 CLK55 AMG
So I asked
The tech did not know what year MB stopped making
the CLK55
Thank-You
D.B
Old Apr 27, 2015 | 06:50 PM
NYC_Z06's Avatar
CLK63 BS
Thanks!
Call them. The rep (Phil?) will walk you through it. Seat type (ball or cone) is dictated by the rim you're using. OEM is ball. Also, lug size is M14x1.5, not M12x1.5.
Old Apr 28, 2015 | 08:39 AM
shellx's Avatar
Thank you!
Old Apr 28, 2015 | 06:42 PM
stewarjm1's Avatar
2008 CLK63 Black Series; 1978 Toyota Land Cruiser; 2015 BMW R1200GSA; 2003 Porsche 996 Turbo (gone)
WAG...same bolt pattern at standard CLK63 AMG
Old May 8, 2015 | 10:13 PM
Jcrame00's Avatar
Juzt had spacers installed this week by Mark J who is on this thread. He did 10mm front / 12mm rear (with extended bolts). I believe he sourced from H&R.
Mark - could you post part numbers for both spacers and bolts if you have free time? Also, did you end up needing to machine polish spacers to match the metal of the stock wheels? Thx
Old May 9, 2015 | 09:30 PM
Jcrame00's Avatar
I just saw my car with spacers installed today.......wow do they look amazing!!
I went 10mm front and 12mm rear with extended bolts (H&R part #'s below). As always with this car,, pics don't do it justice.
IMO, tire gap looks perfect in rear and near perfect in front. You may be able to run 12s all around, but no complaints with current set-up.
Front Spacer: 10mm
Part #: 205 56 659 (front only)
msrp: $99.95 (pair)
Rear Spacer: 12mm
Part #: 205 56 65 (rear only)
msrp: $99.95 (pair)
Front/Rear spacer information
Bolt Pattern: 5/112
Center Bolt: 66.5
Bolt/Stud: Bolt
Thread Type: 12x1.5
Spencer Type: DR
Extended Wheel Bolts
Part #: 145 3502
Thread Length: 35mm
Thread Type: 14/1.5"
Seat Type: Mercedes ball
Head: 17mm
msrp: $4:45 each
Hope this helps......and props to Mark for meticulous installation.
Old May 10, 2015 | 12:20 PM
carsandbars's Avatar
CLK63 Black Series
I'm confused, is the thread type 14x1.5 or12x1.5 ????
Front Spacer: 10mm
msrp: $99.95 (pair)
Rear Spacer: 12mm
msrp: $99.95 (pair)
Bolt Pattern: 5/112
Center Bolt: 66.5
Bolt/Stud: Bolt
Thread Type: 12x1.5
Spencer Type: DR
Part #: 145 3502
Thread Length: 35mm
Head: 17mm
msrp: $4:45 each
Old May 10, 2015 | 02:00 PM
Jcrame00's Avatar
I sent a note to my tech for clarification and will let you knowi. He may respond directly as Mark is on this thread.
Sorry for any confusion, I wrote down part numbers and sourced thread sizing and ancillary data in my post directly from H&R site.
Old May 11, 2015 | 10:42 PM
NYC_Z06's Avatar
CLK63 BS
Thread pitch is 14 x 1.5
Old May 12, 2015 | 11:53 AM
MOFLO's Avatar
Jcrame00,
Please post a picture from a side angle so we can see how the front and rear tires line up to the fenders.
Thanks!
Old May 12, 2015 | 05:17 PM
Jcrame00's Avatar
This is my only side view photo. I'll post better photos when I get back next week. I apologize if photos seem overly large, I need a 101 on photo uploads.
Old May 12, 2015 | 05:32 PM
Jcrame00's Avatar
Quote from my technician below. It does support NYC Z06's response.
"i believe it is a typo on the H&R website, the spacers have a 14x1.5 thread and the bolts are a 14x1.5 thread"
Old May 12, 2015 | 05:36 PM
shellx's Avatar
I can second this as I just ordered spacers for my black and it was 14x1.5
Old May 13, 2015 | 06:52 PM
MOFLO's Avatar
Looks good! Thanks for the side shot.
Seems like you can go a bit wider. 20mm/rear and 15mm/front maybe?
