Transmission Service
Subscribe
Oct 8, 2015 | 12:58 PM
My second most recent track day I noted my transmission was slow to up shift. I have 22k miles with a fair number of track days. I also upgraded to the rev matching program from Weistec but didn't think would that would cause the slow shifting. I checked with my tech at the dealer and he tells me trans fluid change isn't necessary before 40K!
After watching an episode of Wheeler Dealer I saw Edd China (best tech ever) bring a Boxster tiptronic back to life with a complete trans service. Since the tiptronic is a Mercedes sources automatic I thought some of the same dna might carry over.
Long story short had the trans fluid and filter changed and went out last week end and the car performed as good as new. The rev matching even improved on the downshifts.
Just wanted to pass on the information, seem that if your tracking the car you might want to up the service intervals.
Jimmy
Reply 1
Oct 9, 2015 | 08:52 AM
I just had mine changed yesterday and should be picking it up tomorrow. I'll let you know if I notice anything differently.
Reply 0
Oct 10, 2015 | 01:36 AM
722.9 transmission should be serviced every 6 years or 39K
Reply 0
Oct 10, 2015 | 01:40 AM
wow that's great news, thinking about just changing my trans fluids now; because if its the mileage that has to do with the scheduled change, then for sure mine has not been done that ever since the initial delivery, and I don't even know how much longer it'll reach 40k miles... Shoot I don't even know when it'll hit 20k either LOL
now with the Weistec blip shift, haven't done that yet, debating if I should change the fluid prior or after that.
Hmmmm
Reply 0
Oct 10, 2015 | 01:44 AM
If you go to a dealer to do it, make sure you INSIST on them draining the torque converter. You will know if they did by how much fluid they charge you for. If it's 9-10 qts, they did. If it's 6-7, they didn't.
Reply 0
Oct 11, 2015 | 10:54 PM
Good info
Reply 0
Oct 12, 2015 | 11:11 AM
Quote: My second most recent track day I noted my transmission was slow to up shift. I have 22k miles with a fair number of track days. I also upgraded to the rev matching program from Weistec but didn't think would that would cause the slow shifting. I checked with my tech at the dealer and he tells me trans fluid change isn't necessary before 40K!
Jimmy
Hi Jimmy,
Great info, as always. Just curious, did you do both rev-match and valve body upgrade? Because when I did that the transmission fluids must be flushed (have to open up the trans). So my fluids were automatically replaced.
On a separate note, how do you find the OEM brakes on the BS? I just came back from VIR and the brake was getting a bit soft towards the end. I know you track a lot more, just want to get your thoughts on it. THx.
Reply 0
Oct 13, 2015 | 02:34 PM
GeoGeo
I didn't do the valve body hence no trans flush. I think the intervals with track use should be twice as frequent. Seems that the flush really woke up the trans.
Most of my track days is at Willow Springs which isn't too severe on brakes.
I've looked at upgrades and I've tried the Porterfields blue pads which are not has good as the stock pads. I do use Castrol SRF brake fluid which is as good as it gets so I haven't boiled the fluid. If you're looking to upgrade I'd go with active brake cooling first. I notice that the left foot brake users tend to have more complaints.
Jimmy
Reply 0
Explore
Oct 13, 2015 | 09:56 PM
Jimmy
Cool thank you for the input Jimmy. I have Motul fluids and it seems to go soft pretty quickly....I'll certainly do Castrol next time.
BTW I do recommend the valve body upgrade (probably next time you flush the trans fluids). I think it also helps with the shift speed a little.
Reply 0
Jan 11, 2016 | 08:02 AM
Built transmission
One of the best most I think u can do on any 63 n/a or sc is the weistec built box and the have diy self kits make a massive difference on shifting and no slippage it a totally different car now no more lazy shifts
Reply 0
Subscribe
Currently Active Users (1)
