CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Brake line upgrade
Old May 21, 2020 | 05:12 PM
Blk63bk's Avatar
Current: 2007 ML63, 2008 CLK63 AMG Black Series
Brake line upgrade
I'm getting ready to do a brake system overhaul and I wanted to update the lines to SS ones. I can only seem to find the front one. Anyone knows if the ones off of later c63s will fit our BS? Seems to be abundantly available for those cars.
Old May 21, 2020 | 07:23 PM
cm60k's Avatar
If you refers to 07-14 "W204 C63",
then yes, they will fit on your CLK63 BS for sure..
-;-ZAYED-;-
Old May 22, 2020 | 09:00 AM
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
You need two different kits :
W204 C63 AMG for front,
W209-R171 55/63 AMG for rear
I never found a kit with Front and Rear for the CLK BS
Old May 22, 2020 | 10:20 AM
cm60k's Avatar
Why two kits bro..?!?
"C63" Rear hose will fit to CLK63 BS,,
cause "C63" Rear hose is only (22mm) longer than "CLK63 BS" hose, which is good to fit..!!
-;-ZAYED-;-
Old May 22, 2020 | 12:39 PM
Tex5's Avatar
-;-ZAYED-;-
Because often each kit is done for a car (Front and rear). As he need front form C63 and rear from CLK/SLK.
The rear of C63 does not fit for rear CLK BS
Old May 22, 2020 | 01:28 PM
cm60k's Avatar
We already fitted 2012 "W204 C63" F&R Goodridge SS lines into my friends 2009 "CLK63 BS" last year,,
they fit perfectly,,
if i'm not mistaken; 07-14 "W204 C63" Goodridge SS lines Number: "SME0863-4C"..
-;-ZAYED-;-
Old Jun 6, 2020 | 12:48 AM
AVMotorsport's Avatar
'99 Ferrari 355 F1; '93 Acura NSX
Hi,
Just saw this thread. Gruppe M of Japan makes a very nice set for the CLK 63 BS, they custom made a set for my car. They fit perfectly. They are custom made on a per order basis, as the BS is extremely rare in Japan. The owner is a very good friend of mine, so I am pretty sure I can get a set if there is any interest. As for cost, it has been a while since I got them so I will have to ask again.
Alex
Old Jun 6, 2020 | 03:36 AM
cm60k's Avatar
Looks Awesome..
-;-ZAYED-;-
Old Jul 15, 2020 | 09:03 PM
ML63 AMG's Avatar
CL63 AMG
RacingBrake makes the best SS lines for Mercedes, had the, on my ML63 and they transformed how the car brakes and more importantly it even helped traction control as well. Coupled with performance fluid it will transport any braking system.
‘Definitely check them out (I wrote full 1 page review of mine, search for it)
Old Sep 2, 2020 | 10:47 AM
MrBlackCLK55's Avatar
E550 Cab, ML350, CLK63BS - Dearly Departed: CLK55
Looking at doing brakes this off season - namely flushing fluid as i am guessing it is original to 2008. In addition to SS lines, what brake pads has the community had success with?
Any good compromises in performance to brake dust to kindness to rotors? Stay OEM and deal with the dust? Mostly "spirited" driving, no intentions of tracking. Thanks in advance.
Old Sep 2, 2020 | 07:53 PM
JPMD's Avatar
GT3RS
Had new OEM Brembo discs put on about 4 months ago and went with Girodisc magic pads
https://www.girodisc.com/Girodisc-Ma...rs_p_6669.html
Very happy with the performance and feel.
Also no squeaking and significantly less dust.
Old Sep 4, 2020 | 10:02 AM
Thanks JPMD. I checked them out...made in the USA too.
Old Sep 5, 2020 | 05:17 PM
Derekm15's Avatar
CLKBS
I’ve herd from my mechanic that usually has at least two BS in the shop and owns a BS that OEM is the best option.
