CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
CLK63 BS Battery
Old Nov 8, 2021 | 02:34 AM
AVMotorsport's Avatar
'99 Ferrari 355 F1; '93 Acura NSX
CLK63 BS Battery
Hi all, I think Im going to need a new battery. Does anybody have any experience with lightweight battery alternatives, like Braille, or even lithium-ion replacements? If so, could you please share which particular size/capacity battery you chose, and how is it working out for you?
As you know, the battery is one huge heavy brick, and am wondering whether any of these lighter weight alternatives would work just as well. Size is not an issue, I can fabricate a new bracket for it. Thanks in advance!
Alex
Old Nov 8, 2021 | 03:26 PM
NYC_Z06's Avatar
CLK63 BS
I've gone through 2 Braille 21 lbs. and am trying an XS Power battery for the first time b/c the Braille 21 lbs. is/was backordered. They're ~$220/ea. and didn't last long for me and that's w/a trickle charger. Were it not for the smaller battery tray that was installed in my vehicle, I'd have stayed w/the normal sized battery. Just don't think its worth saving a few pounds. Yes the OEM is heavy but its optimally placed for weight distribution, if not access. Guess a Braille is good track day replacement to be swapped back afterwards.
Old Nov 9, 2021 | 03:54 AM
Thanks for the info. I looked up XS Power batteries, which model are you going to try? They seem to have quite the variety. Do you think one of the lithium ion models would work with our charging system?
Old Nov 9, 2021 | 10:31 AM
NYC_Z06's Avatar
CLK63 BS
XS Power Batteries S975 - Part Number: XSP-S975
Old Nov 10, 2021 | 08:37 AM
Blk63bk's Avatar
Current: 2007 ML63, 2008 CLK63 AMG Black Series
I found that taking the battery in and out of our cars can be quite the hassle. I ran optima and Braille for a bit, and found myself worrying about the car starting on a cold day more often than not.
I ended up switching to a interstate AGM (H6 size I believe) and have had a worry free 3 years. Unless it is a dedicated track car, I value the dependability over the weight savings.
Old Nov 10, 2021 | 11:47 AM
NYC_Z06's Avatar
CLK63 BS
Absolutely. I wasn't advocating for lightweights. My BS doesn't have the rear seat delete parts and I still wouldn't want to switch out batteries to save a few pounds. An M156 (w/a SC in my case) requires a lot of power to turn over. So I'd prefer to run a stock size w/greater CCA's and longer life.
Old Nov 11, 2021 | 07:01 AM
Doctodd33's Avatar
ML350
Will one of the newer model Mercedes OEM car batteries work? The SLS uses a lightweight battery.
Old Nov 12, 2021 | 09:24 AM
Blk63bk's Avatar
I believe the SLS is also an H6 battery, so if you do to your parts department you will likely get the same part number for the CLK BS and SLS battery.
Old Nov 12, 2021 | 10:43 AM
Doctodd33's Avatar
ML350
maybe I should’ve specified the SLS black Series has a lightweight battery. I don’t know if the SLS other variations have a lightweight battery.
Old Nov 13, 2021 | 04:22 PM
Yes, the SLS black series had a VERY lightweight lithium ion battery. It also has a third terminal on it, which left us guessing as to what it was for. I think it was for telling the computer how much charge is left in it.
Beware, though, I had to replace one on a previous SLS BS that we had, and it cost us $2700 from the dealer! So may not be a practical option. The XS Power S975 battery is a bargain at $1200.
:-P
Alex
Old May 25, 2025 | 08:32 PM
Condor Man's Avatar
G63, SLS, CLK63 BS, GLE63s, 812GTS, 296GTB, 599GTB, 575M, 992Touring, 356Speedster
Does anyone here have any tips on replacing the Battery on the BS?
many thanks
Old May 25, 2025 | 09:47 PM
duuder's Avatar
500E - CLK BS
many thanks
the lower (rear center) panel pops out, it then exposes a bolt (torx?) to remove the upper panel. The felt/fabric you can I believe and then it's just a giant U shaped thing that holds the battery down
Old May 27, 2025 | 12:22 PM
Condor Man's Avatar
Thank you!
I will give it a go.
Old May 28, 2025 | 05:36 PM
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
I confirm it is torx bolts
MB docs but in french
Not a lot of space if you have the european version with recaro seats
File Type: pdf
Old May 29, 2025 | 03:54 PM
duuder's Avatar
500E - CLK BS
I have the seats and the half cage, it was pretty funny visually...
Old Jun 1, 2025 | 06:49 PM
Condor Man's Avatar
It was actually a lot easier than I thought it would be.
I needed a torques and then popped the cover off.
After this, there were one nut on either side of the battery and two at the front. 12mm.
Job done!
