Bluetooth sound quality issues?
I live in Oregon, and our highways are loud, loud, LOUD! I have never experienced highways so loud before. The roads are very uneven, creating a lot of road noise in the cabin when on the freeway, and I have found that no one can hear me when I use the bluetooth in the car. I have to repeat myself over and over, and the callers on the other end say they hear loud noises and that my voice sounds garbled and indistinct. I called my parents once when I was on the freeway while it was raining, and they thought I was inside a blender. I would simply attribute this to the noise of the rain/road, but my previous TL's Bluetooth sound quality was infinitely better. Also, if I hold my phone in my lap and use the speakerphone, everyone says it sounds a lot better.
Is MB's Bluetooth system just poorly designed, or do I have a potentially fixable issue?
Anyway, just an update. I went to the engineering menu to see if there was a gain setting or anything that might explain my sound quality woes, and I found a setting in the telephone menu under SW settings that was something like "EC/NR." It was set as "Deact" so I changed it to active, and it seems like the quality is better now. I'm assuming EC/NR is "error correction/noise reduction" and I am surprised it was deactivated.
Anyway, I have yet to drive back on our loud highways in the rain, so I haven't fully tested the change, but I'll report back if it turns out that this is not the solution.
If anyone happens to be in the engineering mode, I'd be curious to know what your EC/NR setting is.
Originally Posted by Ali_E55
push these inputs in middle console (hang up phone button) + 1 + # the same time. you will be in engineering mode.
in engineering mode press ( hang up phone button ) + 4 + # the same time . you will be in another menu.
check the version in one of these menus.
you can also change some settings. __________________
I just wanted to thank you for this great advice. My handsfree was essentislly useless till today. The missus confirmed that its a huge improvement.
The local mb dealer appears to be unaware of this setting. And why was it set this way to begin with???
Thanks again!
Thank you for this!
Only negative now is when I connect via carplay, the volume is now reduced for phone calls. So next time I go for service I'll ask them to check on that.
