Door pin removal
By the way, those of you that get the metal replacement kits...make sure you get the set with 2 different sizes since the rears are shorter....and I used some blue locktite
I think the recommended way (take the door panel off) is so if you do want to "push" the new pin over the "ball", you need to push down and you could potentially break the internal levers behind the panel. if you take the panel off, you can push the pin down over the ball much easier cuz you can hold the other end in place.
But if you are OK with gluing in place then I don't believe you need to take the door panel off. BTW if you do the glue technique, the pin potentially stays a bit higher than it is supposed to, do I actually drilled out the inside of the pin so that it would rest where it is supposed to....
W
