Build the most powerful cls550 4matic
Any one knows the part number of the pipes needed to split the IC water cooling from the rest of the engine circuit ?
Would apreciate the help thanks.
I've been looking from the engine bay and my car allready have the IC expansion tank and the pipes related.
So I have to take the car on the lift to look underside and see search for "Y" pipe...
By the way to install the CW100.2 or .3 pump the wiring and plug will be different ?
Any aditional water IC radiator that will fitt with no major mods ?
Were to intersect/connect in the IC water circuit for better flow and cooling with the extra rad ?
i can confirm what dblok is saying if u spin tires the computers cut power like a toyota. Not like a range rover where it just brakes on slipping wheel. Even with 4matic on a 550 with ecu tune u can spin the tires easily and cut power
QUOTE=cls5504matic;8267763]I would really get a 2014 cls 63s, they r faster and they do have lsd in the rear. I think it may have been optional before that
i can confirm what dblok is saying if u spin tires the computers cut power like a toyota. Not like a range rover where it just brakes on slipping wheel. Even with 4matic on a 550 with ecu tune u can spin the tires easily and cut power[/QUOTE]
very frustrating I live in Kissimmee and there’s a decent car scene out here for import, American, and of course your Honda’s but nothing worse than ripping and getting your opening and slamming the gas to take off and power cuts and the car just coast around 25 🤦♂️ After I got it tuned again it didn’t happen while driving but the car nowhere near pulls like the initial tune did, but still beats almost anything around here with ease except for a local hellcat and my friends tuned Gtr. Other than that it’s an absolute blast. I want to track it and really do some serious upgrades to the turbos and cooling system but now this lsd has got me thinking where do I find it and how much is it going to cost because if I’m going to be upgrading to some bigger turbos and I can’t handle the power now I’m going to need the lsd..........
Turn off ESP, dyno mode for complete off
But yo the TCU tune helps out a lot putting power down. I went with morendi and it's not that expensive. I'd guess a lot less than a LSD once u factor install. I would like to put in a torsen at some point though.
But yo the TCU tune helps out a lot putting power down. I went with morendi and it's not that expensive. I'd guess a lot less than a LSD once u factor install. I would like to put in a torsen at some point though.[/QUOTE
Thats right I still gotta do the tcu tune. Weistec sent me an email about it I believe. I’m going to actually look at that this weekend. I’m doing some maitenence on her this weekend, I still got this coolant leak so I’m going to attempt with help to put that lower hose in and hopefully get it in there and fix the leak, if not it’s looking like could be water pump either way I checked and they have it in stock, I also am going to attempt to fix the airmatic valve leak by replacing the airmatic valve unit and figure out where this oil is coming from no check engines amd I will order tcu tune this weekend I think as well and get here ready for a few 1/4 mile runs and a run on the dyno and then back in the garage for more mods lol but that would be sweet to have a nice launch with the stage 2 tunes and see what they are pushing 1/4 mile. I’m going to try turning off tc and put in dyno mode and do a few runs with the original weistec file, I do have both files, plus the stock file so I’d love to see how they perform. Just gotta get through these small issues I got now. Anyway I’ll keep posted on progress and a new thread with tcu tune once obtained and very excited to get some time to put in on the car this weekend
(there was no info as this is the first build m278)Here are some pictures of my cooling setup including the two oil coolers at the front and the Meth in the trunk (pictures taken while installation in progress).
The bottom line: I have invested ~17-20k USD in the build. If i build it again will go under 13-14k as some parts are not required (same as the m278 engine). The most expensive are the M157 turbochargers that you can get as low as 4-5k second hand (they need to be less than 30k miles) and new up to 10k, ECU tuning about 2-3k (few sessions included), intercooler system upgrade 1.5k, Aquamist hfs4 1k, oil cooler upgrade (not needed if your engine is equiped with oil cooler from the factory) 1k including the oil lines and AN10 hoses and AN10 fittings, Exhaust system, full dual 3 inch from the turbochargers to the mufflers 4-7k. Turbo-back downpipes are required (for example my cls63 fell off a cliff after 5.8k rpm -100hp till redline due to restricted flow of the stock turbo-back downpipes), Quaife LSD 1.5k, AMG front and back brakes (required!!) 3k. Labor for engine removal (turbocharges installation) 380 USD here in Bulgaria LOL.. All other installations except the ECU tune are performed by me
including the build of the exhaust, downpipes (including 3d printing and 3d design), meth installation, cooler installations etc..Overall i preffer this car over any rear wheel drive 700hp+ AMG
Will check for the ECU tune and will let you know.
i have just installed amg turbos on my e550 convertible and now ecu tunning is the problem, my tuner can't tune it past 1bar, afr, ignition timing etc everything is perfect in the dyno it put down 500whp but in the street my car is slower than when it was stage 1..
my e550 mods are: amg turbos, amg gts oem spark plugs, cls63 full decat downpipes, separated cooling with big heat exchanger, kn filters, amg fuel pumps. I can feel power below 3k rpm then it dies past that..
have you gotten this figured out? who is doing the Tuning?
I'm having some similar problems and hoping to find someone that can help with my tuning issues. I'm trying to get to 1.5 bar to see where I can safely.run my car. As you my car falls flat after about 4k and literally around 100mph.....
I plan to start and complete mine in 2022 as well, but on a slightly different platform and look forward to the results. I parted out my 2016 S63 coupe after an unfortunate disaster the dealer caused, and kept the turbos, the AMG brakes, and the RennTech gear…As I plan to put that all on my 2013 E550 Coupe.
My plan is similar,
1 Swap out the m278 turbos with the S63 AMG turbos
2. Fab a custom SS manifold/DP set to replace the stock set up.
3. Modify the whole RennTech exhaust to fit the E Coupe, install that along with the 200 CEL free flow exhausts as well as the RennTech SS rear valved mufflers. Thereby replacing the whole stock exhaust set up.
4. Add colder plugs.
5. Fab a custom secondary Intercooler, although I’m considering an interchiller…Either way, cooling has to be upgraded to avoid heat soak.
6. Add water/meth injection…Really like Weistec’s but it’s pricey for what you get and Aquamist is excellent for ahold the price…BTW, the Weistec looks like a customized Aquamist made to their specs…In particular the tubing, which looks first rate.
7. Add a Quaife LSD
8. custom dyno tune from EuroCharged…
9. 19” wheels, probably made to order…
10. Lots of AMG accoutrements for the exterior and the interior, but NO AMG Badge on the Trunk, as the car is not an AMG like my S63 was. I have added the Mercedes “S” to the end of the E550 moniker so it is badged E550s and I’ll ok with that as I’ve definitely modified the car at that point…
11. I’ve already modified the OEM intake boxes so that there is no intake restriction from the stock design and upgraded to K&N filters as well
12. Adding the aftermarket touch screen/apple car play as well as lots of custom carbon fiber parts to the interior…and some alcantara.
I would have done this already, but Covid put a big slow down on a lot of my plans a few year ago…
figured fuel would become an issue, so wil add that to the scope as well.
I’ve built much more aggressive projects in my past so, I’m up for this, just have to set aside the time and will not let the cost get in the way of investing as that paramount in these times…
thanks again for the road map and the inspiration!
I wonder how it will be as a rear wheel beast as my set up is rear wheel…
