W218 - Wheel and Tire Fitment question
I am looking at purchasing some new wheels/tires for my '13 W218 CLS550 4Matic.
While dropping $6-7k on a gorgeous set of shoes might be in the realm of an everyday thing for some, after dropping some coin on the RennTech ECU and Exhaust (only to have them release an updated MAP this week...grrrr) - I'm on a "let's see what the Craigslist has" type budget for some "whillz"
Someone relatively local has a near new set of Vorsteiners, with good looking Michelin rubber, up for grabs.
He says they came off a w212 e63 wagon.
The Fronts are et35 20s - 265/30/20
The Rears are et42 20s - 295/25/20
My questions are:
A: Will they fit without clearance issues?
B: Those are SKINNY sidewalls. How bad is the ride going to be?
C: Will they REALLY FIT? I'm talking, "inside the fenderwell, I can turn lock to lock under loaded suspension without funny sounds, smells, noises, etc., I'm not turning my gorgeous cruiser into some liability that I curse every time it leaves the garage", FIT?
Thanks in advance for the feedback
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
OEM CLS wheels are
front: 8.5 width +34mm
rear: 9.5 width +48mm
Does anybody use on CLS W218
8.5 et 35
9.5 et 35
and what tires will be better?
255/35 R19
285/30 R19
or
245/40/19 front
285/35/19 rear
need photos or link to see this or close to this parameters.
i need understand does rear wheels will rubbing?
thx.
20x8.5 front and 20x10 in the rear
what is the best tire size to accommodate this wheel spec ? also will I need spacers for flush fitment ?
I have: Front - 20x9 +28 with 255/30/20 & Rear - 20x10 +35 with 295/25/20
NO spacers needed.
