Best lowering module
Old Nov 17, 2016 | 12:48 PM
Silence31's Avatar
CLS550
Newbie here...
Trying to lower my CLS and wondering what are some good lowering systems out there. Thanks in advance.
Old Nov 18, 2016 | 10:11 AM
goalie_k's Avatar
2012 GL350
LoMo M1 without a doubt is the best one. http://loweringmodule.com/
Old Nov 18, 2016 | 10:16 AM
Speedriven1's Avatar
Speedriven
Second.
Old Nov 18, 2016 | 01:04 PM
Silence31's Avatar
CLS550
Thanks guys. How hard is it to install? Do you recommend the dealership performing the installation?
Old Nov 18, 2016 | 01:19 PM
Vin Vo's Avatar
2014 cls550 4matic
its not hard at all. There are youtube videos of install and its mostly plug and play. I wouldn't recommend dealership to install unless you want them to void warranty.
Old Nov 21, 2016 | 10:05 AM
Speedriven
This.
An indie shop could also help you- this would be a great intro., also, since you'll want to find a competent local mechanic in addition to the dealer, anyway.
Old Nov 30, 2016 | 02:11 PM
RacingFish's Avatar
CLS550, 57’ Chevy Nomad, Subaru LGT wagon
I run a lomo also. Its by far the easiest to use. To lower or raise your ride height its just a series of buttons on your steering wheel. No need to break out a lap top or tablet, like some of the others.
Old Jan 16, 2017 | 09:47 PM
MrJeeno's Avatar
CLS 550 4Matic
Newbie Here:
Has anyone ever tried the RENNtech V3 Digital Suspension Lowering Module ?
Old Jan 18, 2017 | 05:52 PM
sparacing's Avatar
2012 CLS
I have it and have no real complaints...other than having to connect a laptop or tablet to load settings. The RT app doesn't seem to remember your settings, so everytime you open it, it resets to default settings. (Im an IT guy, but it could be user error...).
That being said, you only really need to set it once and let it be. You can setup the ride heights based on speed. So I keep mine as low as I can get it and have it raise xxx amount at 5MPH, then xxx amount at 15MPH and so on.
If I could figure out how to get the app to save my settings, I'd really just need two....one for car meets and such when I want it stupid low, and another for everyday driving.
-S
Old Jan 20, 2017 | 11:42 AM
MrJeeno's Avatar
CLS 550 4Matic
-S
Thanks for the info. I'm trying to figure out if I should go with the RennTech or the LOMO - What are your thoughts ?
Old Jan 20, 2017 | 02:58 PM
Paulmurphy's Avatar
Cl 500 216
Just fitted a Carlsson lowering module to my CL 500 here In UK it uses existing raise button .
ride height is selected from module from 0 to 30 mm, took 20 mins to fit well pleased with it.
Old Mar 5, 2017 | 02:51 PM
deyainrdy4ds's Avatar
w208
Hey all, new to the 218 board, but not mbworld. How low do these lowering modules get your CLS? Low enough to eliminate wheel gap or would you need a coilover/spring+strut system to get that low?
Old Mar 8, 2017 | 08:33 AM
sparacing's Avatar
2012 CLS
At the lowest setting, my front and rear wheels tuck on the RennTech lowering module. I keep the regular settings to where the wheel gap is removed.
It plugs into the suspension module underneath the passenger footwell.
-S
Old Mar 8, 2017 | 03:44 PM
3WD's Avatar
3WD
SPONSOR
Car
Definitely RennTech. If you need a price quote, please let us know..Thank you!
Old Mar 15, 2017 | 01:56 AM
w208
-S
So you just used that without any change to suspension hardware? Any pics of your setup at highest and lowest settings? Can you adjust it without a laptop?
Thanks!
Old Mar 15, 2017 | 05:34 PM
goalie_k's Avatar
2012 GL350
Lots of pics here: https://www.facebook.com/Loweringmodule/
Old May 23, 2017 | 01:20 AM
w208
pics not showing? any other linkes?
Old Jun 17, 2017 | 08:15 AM
portchop002's Avatar
08 C300 4Matic
-S
I've been looking at the RT and I just want to make sure it goes low enough for me, do you have a pic of the CLS at the lowest setting?
Old Jun 19, 2017 | 12:36 AM
RacingFish's Avatar
Are you looking at the RT because of the name?
Personally I like having the ability of lowering or raising my car through my steering wheel. It takes less then 15 seconds to lower or raise the car and its all done through your steering wheel and it reads out on your dash as to what height. I run 305/25/20 in the rear and at the lowest setting (which I dont run) the wheels are tucked. I run the rear at -5 and there is now wheel gap between the fender and the top of the tire.
Old Jun 19, 2017 | 02:26 PM
sparacing's Avatar
2012 CLS
Sorry, I just saw this...I'll have some pics up shortly.
Old Jun 25, 2017 | 06:03 PM
08 C300 4Matic
I was looking at it mainly due to brand, I'd love to see some pics of the setup especially with some wheel tuck.
Old Jun 27, 2017 | 12:53 PM
sparacing's Avatar
2012 CLS
Sorry guys, I have part of my car torn apart for some additions/upgrades. I'll post pics in the next few days once I have it put back together.
Old Jul 29, 2017 | 12:55 AM
w208
hey man..just checking in to see if you got around to any pictures?
Old Aug 6, 2017 | 03:03 PM
08 C300 4Matic
Do you have any pictured?
Old Aug 17, 2017 | 09:18 AM
sparacing's Avatar
2012 CLS
Guys,
I apologize it took so long for me to get something up.
I shot a video to show the stances of the car.
It's crappy, but I'm just starting to do videos...this is my second. Hopefully it's helpful.
