weird sound on turbo when starting up
Old Jun 24, 2017 | 02:57 AM
TTMBCLS's Avatar
cls550
has anybody notice the turbo sound when they start there car. my right side turbo makes a scraping/flapping noise right when i start it up. It sounds like it does not have enough oil and it scrapes or flapping. When the car is warmed up the sound goes away. I thought these were state of the art turbos? does my turbo have shaft play or something? i probably need more oil or an oil change. at 8k already. On cold starts it is a lot more noticeable then you can hear it change noise.
Old Jun 24, 2017 | 03:24 AM
TTMBCLS's Avatar
cls550
i think sometimes my wastegate doesnt close all the way and it makes those sounds. i try to put wd40 on where the outside of the wastegate flapper. after a week it still make the noise. my car drives fine and boost hits on the top end just fine. but when i start it up the noise comes and go.
Old Jun 24, 2017 | 04:30 PM
TTMBCLS's Avatar
cls550
Sound clip this morning . kind of hard to hear it in this video but its there.
https://m.youtube.com/watch?v=LPHqEv5lSA0
Old Jul 9, 2017 | 09:51 AM
pgolfco's Avatar
2018 Lexus LC500, 2020 GLE350 4Matic, 2005 Jeep Wrangler
My CLS makes the exact same noise, but hot as long as yours. Mine goes away very quickly. Should I be concerned?
Old Jul 11, 2017 | 07:43 AM
Acidic Reflux's Avatar
2013 Mercedes CLS550 RWD
I have the same sound coming from my cls on cold start ups. Hear it for about 3-4 seconds and then goes away. Got it checked at the dealership and no faults were found. I guess its normal.
Old Jul 11, 2017 | 08:26 AM
pare5's Avatar
2012 E550
Those are your chains..... take it to the dealer and have them take a look at it. Either needs just tensioers and check valve or tensioners, check valve and new chain.
Old Aug 15, 2017 | 11:02 PM
TTMBCLS's Avatar
cls550
Update: changed my oil and use my car everyday now. The noise is not there anymore..back then i didnt drive the car for a few days it was noticable but its gone now.
Old Aug 15, 2017 | 11:38 PM
TTMBCLS's Avatar
cls550
Hi acid reflux. I can hear the same noise as you. Does this happen to be only on one side? I am still guessing its lack of oil going to the turbo. Can't tell for sure.
Old Aug 16, 2017 | 04:37 AM
Bro it was exactly what pare5 mentioned. it was chain tensioners and valve problem. I got it fixed at the dealership. It seems like a common problem with M278 engines. My car is only 8000 miles driven and this problem occured. Its better to get it fixed before it stretches the chains which can cost a lot more.
Old Aug 16, 2017 | 01:26 PM
TTMBCLS's Avatar
cls550
The sound is not from the timing chain. This noise is coming from my turbo.
