Looks like i'll be doing service B for myself
Old Dec 27, 2017 | 12:24 PM
netienne's Avatar
2016 CLS550
Ive got a 2016 CLS550 and its time for service B. I schedule a service appointment with the dealership near me (Pembroke Pines, Florida) and ask for an estimate of what it would cost. Service Advisor tells me aprox $1300. Nope, i dont think so
Has anyone else done service B, and if so where are you located and about how much did it cost?
Anyways, I just now purchased via Amazon...
--oil filter (oem part 276 180 00 09 - based on the part that was listed on my service A from dealership)
--mityvac 7201
--mobile-1 5w-40 formula M motor oil (approved for MB 229.5)
--engine air filter (oem part 278 094 00 04)
--cabin filter (compatible with oem part 2128300318)
as soon as it all arrives, it looks like i'll be doing most of service B myself. i'll update this thread to let you all know how it went.
does anyone know if oil filter part 276 180 00 09 is indeed a fleece filter?
can anyone recommend the correct oil filter wrench to use for CLS550?
service B includes "Clean water cowling to ensure proper drainage"; any advice on doing this?
any advice on DIY maintenance is more than welcomed (oil change, replace engine air filters, replace cabin air filter, etc).
Old Dec 28, 2017 | 09:34 AM
netienne's Avatar
2016 CLS550
fyi, turns out you dont need to go out of your way to get a "oil filter wrench"
example of oil filter wrench
looking in my garage i found the following which will do just fine.......
2016 cls550 oil filter housing
Old Dec 28, 2017 | 10:06 AM
OBP's Avatar
OBP
E63 S AMG, CLS550 4matic, C63 Ed 507, Volvo XC90 T8s
Doesn't service B include a brake bleed ?
Old Dec 28, 2017 | 05:47 PM
netienne's Avatar
2016 CLS550
I think it does require a brake fluid flush. I’ve done it on my dodge truck but I’m not yet comfortable enough to do it on the Benz. More research on my part before I attempt a brake bleed on the Benz
in the meanwhile I’ll take it to an Indy shop so they can do the brake bleed
Old Jan 7, 2018 | 09:07 AM
sxs191's Avatar
2014 CLS550 4matic AND 2010 C300 4matic
Brake bleed is easy on theses cars. Get yourself one of these pressurized systems and it’s a piece of cake. https://www.motiveproducts.com/colle...ropean-bleeder or just do it the 2 person system and make sure u don’t pump the reservoir dry in the process.
Old Jan 10, 2018 | 12:06 PM
netienne's Avatar
2016 CLS550
took a while for me to get the parts from Amazon, but they finally came in (MityVac, oil fiter, 5W-40 oil).
however, ive already run into a little snag.
I ordered oil filter A2761800009 (this was what was even listed on my invoice from dealer for service A). however that part does not fit my 2016 CLS550
Furthermore, when I removed the current filter I have an its actually a "Hengst AMG A2781840125"
So the dealership invoiced the wrong oil filter. Go figure!
I will now order a ECOGARD X10186 Cartridge Engine Oil Filter
what i ordered... OEM A2761800009
the oil filter that was currently in the CLS Hengst AMG A2781840125
what i will now order ECOGARD X10186 Cartridge Engine Oil Filter
Old Jan 12, 2018 | 10:59 AM
netienne's Avatar
2016 CLS550
done with my oil change and replaced air filter.
i still need to replace cabin filter, which i will do at a later time.
two youtube videos that came in handy....
Old Jan 23, 2018 | 09:35 PM
VirtualRain's Avatar
2016 CLS550 4Matic
Watching this thread... great stuff!
Old Feb 14, 2018 | 10:12 AM
durand's Avatar
2003 c230 coupe
Try star garage in Margate ask for Mike or Joe they do great work on high in mercedes and they are cheap
Old Mar 12, 2018 | 08:05 PM
Suppaa Mario's Avatar
CLS 550
How did everything go? I'm debating about doing this service my self.. Oil and air filters... I'llet the dealership do the break bleed
