Lane Keeping future doesn't work
Old Jul 28, 2018 | 07:15 PM
mitch550's Avatar
CLS550
Greeting!
after I lost 1st gen CLS550 by the traffic accident a couple months ago, I had spent quite tough time,
but now, I am very happy with my new one, 2014 Black.
Although I still am fond of the original style, I found myself enjoying much more advanced features of C218.
Now I would like to get your advice on the lane keeping assist, which doesn't look work properly.
When either standard or adaptive on Lane Keeping assist is chosen, the car warns me by vibrating the steering, but it doesn't correct the driving direction.
The green line appears on the graphics display when the velocity reaches the enough speed, however, at vibration the green line doesn't turn red, nor there is no correction of the steering.
I search internet and read the manual, but I couldn't find anything else I can do to enable that feature.
Your advise is very much appreciated.
The road condition I tried is one solid straight line the other broken line.
Cheers!!!
Old Jul 29, 2018 | 03:30 AM
VirtualRain's Avatar
2016 CLS550 4Matic
I don't know exactly how it works, but there's a single yellow center line on my neighbourhood street and it often vibrates if I touch or cross that line but it's never corrected the steering. I say that because I'm rarely going over 50km/h (30mph) on this street. The other day, I was going fairly fast on a main road and cut across the shoulder line a bit early to make a right turn and it worked... but I found it very jarring and unexpected. I was like WTF was that?! I was not expecting it. So I wonder if its speed related? Maybe you have to be going at a fairly high speed for it to correct the steering. But in my case, I'm considering turning it off. If it's going to start correcting my steering when I'm intentionally crossing lines to go around other vehicles (for a variety of reasons), then I don't want it. Of course if you signal, it seems to ignore any line crossing but I don't always signal when I'm making a move and no one is affected by it. But I'm admittedly an aggressive driver and don't need some automated system telling me how to drive.
Old Jul 30, 2018 | 12:29 AM
Suppaa Mario's Avatar
CLS 550
Originally Posted by mitch550
Greeting!
Cheers!!!
Bump. i am curious about this because in mine i have yet to see the lane keep assist help move the car into proper position at any speed...
Old Jul 30, 2018 | 08:09 AM
Acidic Reflux's Avatar
2013 Mercedes CLS550 RWD
My car never corrected me either. Every time my car went out of line without proper turn signal my steering would vibrate three times and that is it. I think its more of a notify you rather then correcting you feature. I did not have distronic plus but only lane keeping feature.
Old Jul 30, 2018 | 08:25 AM
mitch550's Avatar
CLS550
Hi guys
Thanks a lot for the response.
I kept researching the feature, that seems to be primitive capability...
But at least I like bind spot and parktoronic, working very good.
Old Jul 30, 2018 | 10:42 AM
2014CL600's Avatar
Cars
I also am having the same issue. When I get the chance, I'll have my MB dealer pick up the car and have all the warranty work done at one time. I don't drive the car enough to deal with those issue right now but once repaired, I will give you the exact answer not speculation.
Old Jul 30, 2018 | 11:27 AM
TNTim's Avatar
2012 CLS 550 Launch Edition
The vibration is just a warning, if you continue to drift over the line it'll turn red on the dash and correct you. Apparently the system works up to 120mph! I'm not sure I'd want the brakes to be applied on one side of the car at that speed! lol.
I've turned mine off, it has dragged me towards more 18-wheelers and through more potholes than I can remember. It's a completely pointless feature/gimmick, IMO, as keeping in your lane is a pretty fundamental part of driving and if you can't keep yourself in the lane, maybe you need to have some more practice
Old Aug 1, 2018 | 11:27 PM
CLS 550
2014 cls here. I just tried it and it does not correct, it simply vibrates Line is green then turns grey .. Is this something the dealership should be aware since my car is still under warranty .?
Old Aug 1, 2018 | 11:37 PM
2014CL600's Avatar
Cars
YES
YES!!!!
Old Aug 1, 2018 | 11:47 PM
CLS 550
Originally Posted by 2014CL600
YES!!!!
Do you have a cls 550 2014 ? I only have the lane keep assist . Don't have the distronic. Did you reach out to your dealership ?
Old Aug 2, 2018 | 12:01 AM
2014CL600's Avatar
Cars
Yes, I have a 2014 CLS550
Yes, I have all the options but haven't had a chance to deal with the issue. It isn't a daily driver and I'm dealing with an illness in the family. It's not a priority at the moment.
Old Dec 4, 2018 | 09:52 AM
TechSuperstar's Avatar
15' CLS400
Keep in mind there are a few levels / packages out there and you may or may not have the active lane keeping assist package (I don't know what the package option code is, maybe someone else can post it). For example my CLS has options 22P-"Track Package" and 476 - "Automatic lane recognition". So basically mine will also knock the steering wheel when hitting the yellow line but it will NOT correct for you. Look up your VIN and see if you have the "Active Lane Assist". Again, someone else please post the option.
Old Dec 4, 2018 | 11:14 AM
2014CL600's Avatar
Cars
thank you but as state before mine has every single option offered
My CLS has every single option offered and it's not that it isn't there, it is that it goes INOP. My car even as a Designo package and listed for over 90k. It's not a matter of if I have it but why it isn't working correctly. I thank you for your response.
Old Dec 4, 2018 | 02:13 PM
rumb's Avatar
cls550 2014
I talked to our local dealer about that screen and she said it doesn't do anything at all. It's not even in the owners manual anywhere. Just some weird useless screen.
Old Dec 5, 2018 | 10:54 AM
konigstiger's Avatar
'71 Pinto
Check data card https://www.datamb.com/ to confirm if you have code 476 lane keeping assist (no correction just vibration) or 238 active lane keeping assist (correction).
