CLS400 sound system...quality? Mine doesn’t sound good
Old Jun 7, 2019 | 10:34 PM
Jambert Corpus's Avatar
CLS400
I have a 2015 CLS400 that is equipped pretty well.
However the sound system is sub par at best. I sat in an E Class and that system sounded amazing and it was 2014
How are your experiences?
Old Jun 8, 2019 | 12:52 AM
Tbbt CLS's Avatar
2013 CLS550 4Matic OE Tuned
What sound system do you have? Base? Harman Kardan? Or? Marv
Old Jun 8, 2019 | 01:58 AM
CLS400
Harman Kardan
Old Jun 8, 2019 | 11:23 AM
Tbbt CLS's Avatar
Harman Kardan
My 2013 CLS550 also has the Harman Kardon and it sounds great. I'm not an audiophile, however. Have you checked fuses to be sure your sub is working? Seems odd that it would sound different than the E350 system. Just last night mine did something it hasn't done before. It took me a few seconds to notice that I couldn't control the volume. I then noticed that the parking brake light was on in the dash. I wonder if you have a fault code that doesn't allow the audio system to perform correctly. Good Luck, Marv
Old Jun 9, 2019 | 02:39 AM
CLS400
Thank you, I have not checked for the fuse. I’ll do some research to find out more about it. Unless you have info for it?
Old Jul 14, 2019 | 07:06 PM
cls5504matic's Avatar
C63 Vert
you may also consider resetting the audio system.
Old Jul 17, 2019 | 06:59 PM
splackabenz's Avatar
CLS 550 4MATIC
Do yourself a favor and turn off the Logic 7 option in the menu. I hated the sound until I did that and it sounds much better especially with Bluetooth or satellite radio. The HK speakers are not the best on the market but the logic 7 definitely does not work for today's compressed audio files. Logic 7 may sound better with CD audio but I have yet to try that.
Old Jul 19, 2019 | 05:49 PM
regigoaks's Avatar
2016 CLS400 RWD
I thought my Harman Kardon with Logic 7 sounds bad at first... Then I start to play around with the settings and figured out that the reason why my sound quality was bad is because I had turned on "Boost" on the volume settings. Once I put it back to "Standard", Bluetooth music with Logic 7 on sounds great actually!
Old Jul 19, 2019 | 06:36 PM
CLS 550 4MATIC
Oh I forgot about the boost, I'll get to that when my car gets out the shop. So looks like the fix is to turn off boost and logic 7
Old Jul 19, 2019 | 07:58 PM
regigoaks's Avatar
2016 CLS400 RWD
For me, the boost is the only one messing up the quality of the sound system. After turning off the boost, I tried Bluetooth music with both Logic 7 on and off; and imo Logic 7 on is better.
