CLS400 Auto Start/Stop
Old Sep 6, 2019 | 05:59 AM
Idklol69's Avatar
CLS400 4Matic EC Tuned
The feature works when the A/C is not on. The feature also sometimes doesn’t work, let’s say I stop at a red light, sometimes it shuts off, sometimes I have to hold the brake for about 4 seconds and then it shuts off. Sometimes it the A/C is on 1-2 fan speed, it shuts off, but 90% of the time if the A/C is running, it never ever shuts off. Is my auto start stop functioning correctly, or does the auxiliary battery need to be replaced? I was with some family and their GLS550 has the A button with a circle for auto start/stop, and they had the A/C on full blast every time, and the SUV turned off at EVERY stop.
Also, sometimes it doesn’t even shut off at red lights, and the a/c isn’t on. The car’s temperature is also how it is when you’ve been driving it for a while, and the outside temperature is 20-30 degrees Celsius.
Old Sep 13, 2019 | 04:27 PM
SwoopyRoofAWD's Avatar
2016 CLS400
The start stop will turn off if it determines it doesn't need the engine running to keep the cabin cool, doesn't matter the fan speed ect. I use the auto setting and in Florida if the system will turn off if the cabin is cool but start many times before I leave from a stop as the sun has made it to hot to keep cool without the ac compressor and engine running.
Also you have to have the pedal depressed a certain amount or it will not shut off or push down into "hold" for the brake. Also regardless of if the AC is on if the system may also stay on for airmatic (if equipped) or if you have the car in sport. Eco/Start Stop is functioning just like it should from what you described. THe GLS550 you described actually sounds like it has an issue if the auto system shut off all the time. Also keep in mind if they dont have the AC on and the fan at full blast it will still shut off.
Old Sep 13, 2019 | 04:39 PM
Idklol69's Avatar
I don't think the GLS550 had a problem, it has one of those A buttons with a circle, I think with the newer cars, it stops every time, regardless of the climate control settings.
Old Sep 15, 2019 | 01:03 AM
Idklol69's Avatar
Now that it was raining here and I needed to use the defrost for the windshield, and while the defrost was running, the car refused to turn off at stop lights. I guess the system is kinda trash lol.
Old Oct 22, 2019 | 02:11 AM
raymond2's Avatar
2016 Mercedes CLS400 Base 3.0 Twin turbo
I visited the dealer few months ago because of Stop & Go functions did not work any more while it is under warranty(2 months to 3 year coverage). Mechanic checked while I was out and called to come back. They did not do anything and said I need to re-charge the battery or replace it since I am using my dash-cam all the time and it drained the battery. Because of that they cannot cover and replace the battery by the warranty. I disconnected the dash and drive around for while, Stop & Go started working for couple days but now it has been completely stopped. No matter how hot or cold, AC on or Off, it is not working anymore. Dealer suggested to change the battery and stop using un-authorized dash cam! I will let you know after I replace to new battery.
Old Oct 22, 2019 | 04:07 AM
Idklol69's Avatar
Which dash cam are you using? I'm planning on getting one sometime this year, and I was worried about battery drainage and the stop and go feature not working.
Old Oct 22, 2019 | 09:04 AM
shortspark's Avatar
2017 CLS550
I have solved every conceivable problem noted above and other problems known and yet to be discovered with the Stop/Start system, and it is quite an easy fix too. I get in the car, turn it on and disable the Start/Stop button immediately before putting the car in gear. All total it takes 0.8 second. No more air conditioning wear, no more starter stress, no more battery replacements and power issues, no more jerking, no more wondering if it is actually working properly or is broken - no more nothing. Never a problem and it works every single time. Of course this means I don't have Stop/Start feature which to me is a good thing because I don't want it and I don't need it. On a big v8 twin turbo it does not save gas, at least not for me. This feature might help with emission control in big city traffic where pollution is compounded by huge numbers of emissions but it is negligible here in the deep, rural country where I live. It is the one thing on my CLS that should it ever break it will not be fixed.
Old Oct 22, 2019 | 04:38 PM
Tbbt CLS's Avatar
2013 CLS550 4Matic OE Tuned
That's exactly why I shopped the entire USA for a low mileage 2013! No Stop/Start system.
Old Oct 23, 2019 | 04:04 AM
Idklol69's Avatar
Which dash cam do you have and is it hardwired so that when the battery is about to die but there's enough juice to start it, the dash cam shuts off?
Old Oct 23, 2019 | 07:48 AM
shortspark's Avatar
2017 CLS550
I don't have a dash cam, never had one.
Old Oct 23, 2019 | 07:48 PM
raymond2's Avatar
Dashcam need separate battery
I actually installed it hardwired by professional but didn't listen to him to add additional and separate dashcam battery. Evenif this car equipped with Auxiliary battery in the trunk, it still drains the juice and I cannot start the car couple times because of this.
As Shortspark mentioned in the thread, I am not a bigger fan of Stop/Start function anyway but only getting rid of the feeling that some function of my Mercedes does not work!
So, If you really want to hardwire the dashcam, I strongly suggest installing small, rechargeable & designated battery for dashcam. Mine was two channel that can record front and rear, which will even drain more power from battery.
Old Oct 26, 2019 | 08:31 AM
rumb's Avatar
cls550 2014
If your heat or cool settings are not being achieved the system will not turn engine off. With defrost on it should not stop engine. System requires a very strong battery to work. If you set your thermostat to 60 degrees it won't work.
