Door Projector Lights
Does anybody have door projector lights installed? I bought two different kinds back in August, both didn't fit, so I gave up on the search lol. If anybody has them, preferably the ones with just the emblem along with "Mercedes-Benz", that would be great. An image is attached of the ones that I currently have that originally came with the car, and a link from Amazon for the ones I bought that never fitted. It's kind of dark in the picture, but to the right is the power connector.
Here’s a link of the ones that didn’t fit:
Here’s a link of the ones that didn’t fit: https://www.amazon.com/Redcrystal-Me.../dp/B0783P9ST2
pgolfco (12-12-2019)
https://www.ebay.com/itm/2X-LED-Logo...7/163494031109
These fit my 2016. One of best add-on I have installed. Gets lots of compliments every time.
Are you sure that the one from Amazon doesn't fit? It looks the same as ones I got from eBay. LED works in only one direction, so try to plug the connector in the other way.
These are what I have fitted on my 2012:
WFB Car Door LED Logo Shadow Lights 2Pcs (CLA CLS) https://www.amazon.com/dp/B077KXYG1N..._P2cYDbT600JHV
perfectly but as noted by another poster, they only go in one way and I recall that I had to turn the rears
around, which was a bit tough with the short wires.
I also get many complements on them.
times 2
Front doors were simple, the rear right door I had to yank the wire a little and more of it came out is it was really short. The back left one caused the most problems, the cable was so short that the connector wouldn't even come out to make it visible for me to put the new one inside. Had to take out the red light and then insert the new one through the red light's slot, and then put the red light back in. Back left one is also very loose, so I gotta do something about that.. Rest are fine and they work great.
I had the exact same issue with the shorter wires on the back door and had to remove the red (reflector?) to make it work as well. A little challenging, but not too difficult.
Tbbt CLS (12-12-2019)
My ghost lamps finally arrived for China, via Amazon. 8 weeks LOL .. simple install they look great..... nice $18 investment to add a little bling to my GLC 300 Thanks for all the help in here...
I used pliers to hold the connector and plug into the projector. Mine are a little fuzzy, like they aren't aligned perfectly well when projecting onto the ground, but honestly pretty cool and my kid and GF loves them.
