M278 to M157 turbos and AMG fuel pumps?
I will use CLS/E63 brake hoses. Should be much easier to install than my oem. I will update the dust shields also. CLS550 dust shield are smaller than 360mm front rotors and don't cover those so well. I will post the update version stuff later.
I did bought CLS63 Carbon Ceramic dust shields and you can see how much bigger they are vs. Oem. Oem don't even cover well the rotor. Might also look a bit better.
So yes now AMG caliber, brake hose, dust shield and Paragon rotor ring with custom fab. hat is installed. My friend did centered the hats in his shop and put a little yellow paint to see if bolts are gonna get loose for some reason.
I did bump C63 AMG forged wheels so nice price that I have to bought those. I like the looks now.
And the second thing that happened was I bought second set Mercedes C63 AMG wheels, that are the lightest that have done to these cars.
Material is Magnesium aluminium. 19x9 wheel weight is 8,2kg / 18,07 lbs. Yes you read it right, just can't believe how light it is.
I will might make a post for these later.Those first C63 AMG wheels that are in my last car pics was made by Otto Fuchs. They manufactured these wheels on behalf of Mercedes-AMG. Since they exclusively manufacture forged wheels, these FUCHSFELGEN are forged,The wheel with the OTTO FUCHS marking 38095.011 weighs 11.05 kg and the wheel with the OTTO FUCHS marking 38096.011 weighs 10.78 kg. I like a lot these wheels. Looks great on cls.
After oil pan stuff was oil change. First time the oil is 5W50 series. Motul 8100 Power API SP. Car runs now so smooth and light throttle. Not just the oil but new intake stuff and less rotation mass. Next week the rotation mass should be even less than now.. Pretty much less. Will see do I get all stuff.
These are the lightest wheels I have ever touch in my life at this size. Magnesium aluminium. AMG Edition 1. Pretty rare. APP TECH Italy done those for Mercedes AMG.Front: A2054017400 9 x 19 ET25 = 8,2kg
Rear: A2054017500 10,5 x 20” ET57 = 9,3kg
For comparison my cars oem wheel weight was front 13,5kg and rear 15kg. Truly terrible. (Haven't ride those for years and sold those)
Due the fronts are 19" and rear 20" I need special tire combo to my 4-matic to work properly. Will see how the car will look with these. Weight reduce with these + light rotors will be amazing. I need to ceramic coat those wheels.
305/25 20" Michelin PS4S
19" & 20" Magnesium wheels, by APP TECH Italy. C63 AMG OEM wheels.
Aluminium paddle shift extenders came along also, but I did take those away. Airbag is not fully its place in the pictures.
Look is a bit fresher now, than it was.
AMG menus gauges are working also.
