Where to begin
Old Aug 8, 2022 | 06:55 PM
gNasty's Avatar
2012 CLS550
Where to begin
2012 MERCEDES-BENZ CLS550 4MATIC
VIN: WDDLJ9BB2CA033194
Flushed my transmission and torque converter. Pulled conductor plate to clean solenoids. Upon reinstall my car won't start or change gears. I did get it to start twice after install when I needed to run car to flush the torque converter. Had trouble before those two times and haven't been able to turn over since. The following codes failed.
_pts
U044700 implausible data from the Central gateway
U044700 implausible data from control unit transmission
_Park tonic u044700
implausible data were received from the Central gateway
_ism shift module a80
P179d00 redundancy system for direct select was activated
_tsm 1709 can communication with control unit a80 (intelligent server module for direct select )has a malfunction
U115100
Communication with switch group warning system has a malfunction
_Driver side Sam front signal accusation and accusation module
C44700
Implausible data were received from the Central gateway
-left xenon headlamp e1n1
U10388
Communication with diagnostic can bus has malfunction bus off
U103811
Communication with diagnostic can bus has a malfunction there was a short circuit to ground
Please help point me in the right direction. It's been undrivable for weeks and my only transportation.
Old Aug 8, 2022 | 10:37 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
FYI..........
is cross posted over to w212 section...
Old Aug 9, 2022 | 12:15 AM
gNasty's Avatar
2012 CLS550
Yeah is that not allowed? Feel like the 212 section your much more likely to get an answer bc of how many people have e vs cls
Old Aug 9, 2022 | 11:08 AM
konigstiger's Avatar
'71 Pinto
Conductor plate is considered a theft-relevant part that may require clearing fault codes & conducting initial startup using Xentry even if reusing part.
File Type: pdf
