CLS Coupe (C219) Discuss the CLS Coupe.
Disable SBC for pad replacement
Old Feb 5, 2011 | 02:44 PM
Kirkdob's Avatar
2012 CLS-550 / 2015 GLA-250
I have read the posts regarding the disable procedure with and without a scan tool. The procedure without seems quit involved. Question: Can we just disconnect the batteries and proceed with the brake job?
Old Feb 5, 2011 | 02:57 PM
j21importer's Avatar
07 E63, 04 discovery
the easiest and best way to disable sbc is to disconnect it under the hood at the unit. just pull up on the tab for the electrical connector and the connector slides off the unit. then reinstall the connector when finished and pump the brakes before starting.
Old Feb 7, 2011 | 12:28 PM
Art-by-Art's Avatar
2007 CLS550
See attachment below for Mercedes Procedure "Disable SBC self-test and apply brake pads, without STAR DIAGNOSIS" for the 2006 CLS. FYI to others SBC is on the 2006 CLS models, but not installed in subsequent years.
Mercedes CLS Disable_SBC_self-test_and_apply_brake_pads,_without_STAR_DIAGNOSIS.pdf
Old Feb 7, 2011 | 10:13 PM
Kirkdob's Avatar
Are there any problems with warning lights or codes after disconnect and reconnect?
Old Feb 8, 2011 | 10:30 AM
Kirkdob's Avatar
Attachment 202309
Thanks!
Old Feb 8, 2011 | 11:10 PM
nope. a couple times i have had a message but when system pressure is achieved it goes away
Old Feb 25, 2011 | 09:09 PM
Kirkdob's Avatar
I did the front pads today. Installed Monroes and they stop great, no noise. I do have one reamaining question. The disable procedure states the brake light will flash 3 times to signal successful reactivation. I didn't get the three flashes, but instead got a steady brake light on after the 50 second waiting period. The brakes did activate during the time when I was turning the left front wheel. The brakes are working great and no warning lights. Is it possible the 3 flashes are for some models and steady lights on for others?
Old Jun 17, 2024 | 03:34 PM
Melvin Phillips's Avatar
ml320cdi
SBC didn't hibernate before I changed rear pads on my 03 SL350
Hi,
Can anyone help. I thought I had switched off the SBC before changing my rear pads, now I have the dreaded red warning and constant beeping. Have I damaged the unit? Noticed the fluid had dropped below min also.
Old Jul 2, 2024 | 01:49 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Try to open/close door a couple of times. Also lock/unlock the car. The SBC unit checks/cycles the system under certain conditions (like unlocking the car, opening the door etc).
Fyi, I recently upgraded the brakes and I only disconnected the big connector on the SBC unit. If you dont open the doors etc during the time the connector is loose, it wont throw errors.
