CLS Coupe (C219) Discuss the CLS Coupe.
Chrome peeling away on cupholders? Here's what I did (DIY)
Old Oct 11, 2011 | 11:54 PM
jtoma878's Avatar
2006 CLS 500, 2001 CLK 320, 1984 300D
I've only had my beautiful love (06 CLS 500) for a month now and my only complaint this far was the peeling chrome trim on the cupholders. So, I decided to do something about it.
First I started off by separating the chrome ring from the cupholder itself. i did this by hand when while just sitting in the car I was fidgeting with it and noticed it could be separated. Mine was able to be pulled apart by hand, but I could see using a utility knife to pry apart. There is no adhesive, it just forced in there. There is a grey rubber gasket between the chrome and the rest of the cupholder. Be careful, there are little fins protruding from the bottom of the chrome ring that fit into the rest of the unit. Don't break them.
After I had it separated, it was pretty easy. I used 60 grit (thats what I had handy, 80 might work fine too) and sanded off all the chrome. This took a little elbow grease, and you have to be careful not to alter the shape of the plastic underneath the chrome plate by sanding too much off. Repeat with 400 & 600 wet sandpaper.
From here, 2 coats of plastic primer (white) then 3 coats of flat black followed by 3 coats of Matte Clear Coat. All paints are Rustoleum.
Let dry, line up fins and carefully push back into place.
Total cost was about $20, and took total hour of labor (not accounting for paint drying time) - beats the hell out of the $80 the stealership charges for the full unit which will most likely just peel again.
Any questions feel free to ask!
Attached Thumbnails Chrome peeling away on cupholders? Here's what I did (DIY)-img-20111002-00030.jpg   Chrome peeling away on cupholders? Here's what I did (DIY)-img-20111003-00039.jpg   Chrome peeling away on cupholders? Here's what I did (DIY)-img-20111004-00040.jpg   Chrome peeling away on cupholders? Here's what I did (DIY)-img-20111007-00057.jpg   Chrome peeling away on cupholders? Here's what I did (DIY)-img-20111007-00058.jpg
Old Oct 11, 2011 | 11:56 PM
Xposure's Avatar
CLS55 M6
Awesome looks great!
Old Oct 12, 2011 | 09:57 AM
Cartronics's Avatar
Former Vendor of MBWorld
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
Great write up!!!
Old Oct 12, 2011 | 09:46 PM
jay ridah's Avatar
CLS 550
mines are slightly peeling as well. i might have to take your advice and just hit it up as well.
Old Oct 12, 2011 | 11:25 PM
CLSED550's Avatar
CLS, Grand Cherokee, Range Rover HSE, 70 cuda 440+6
It's so funny that you posted that. I just got my 08 CLS 550 and the one thing that bothers me is the cup holders. Chrome is peeling on mine also. Good job. How much to do mine ? Hahaha
Old Oct 13, 2011 | 02:01 PM
toreador's Avatar
CLS 550 2010
Nice! I wonder if we could use some sort of highgloss metalic paint and make it look almost stock.
Old Oct 13, 2011 | 03:00 PM
pkalona's Avatar
2007 CLS550, 2008 BMW 335, 2007 Harley Davidson Fat Boy
Had my peeling cupholders and inside doorhandle replaced under warranty. For such an expensive car, it seems like poor attention to detail on MBs part.
Old Oct 13, 2011 | 03:37 PM
CLSED550's Avatar
I am going to try to take this on this weekebd. Keep you posted.
Old Oct 15, 2011 | 10:50 AM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
if ur advisor is good the dealer will change it.....got mine to a new one....
Old Oct 15, 2011 | 11:43 PM
ontilt's Avatar
CLS63
mine were replaced under warranty..but am sure they will peel again when my warranty is up..this will be handy thanks..
Old Aug 2, 2013 | 07:40 AM
bgbarton's Avatar
Mercedes-benz CLS 350 CGI
Chrome peeling away on cupholders? Here's what I did (DIY). I did it too!
Hi
Big thanks to jtoma878 for his post back in 2011 on this subject and his fix. I had the same problem on my CLS 350 CGI and here is the result of the fix. Mine seem to have slightly more lustre even though I have used the recommended Rostolium products, but excellent result so thankls again.
Attached Thumbnails Chrome peeling away on cupholders? Here's what I did (DIY)-dsc_3921a.jpg   Chrome peeling away on cupholders? Here's what I did (DIY)-dsc_3924a.jpg   Chrome peeling away on cupholders? Here's what I did (DIY)-dsc_3931a.jpg
Old Mar 9, 2014 | 01:53 AM
bigz1969's Avatar
2009 CLS
If you soak the chrome ring in bleach for a few days the flakey chrome dissolves.
Old Jun 22, 2016 | 02:54 PM
benbac's Avatar
'06 CLS 500
Does anyone have instructions on how to remove the entire cup holder assembly?
I'm going to paint the rings along with the coin discs at the bottom of the cup holder which have started bubbling and peeling.
Old Jun 22, 2016 | 02:56 PM
benbac's Avatar
'06 CLS 500
Nm, I should've read other threads before jumping the gun ... https://mbworld.org/forums/cls-coupe...ml#post5800290
Old Aug 19, 2017 | 10:57 AM
CakeDaddy's Avatar
Silver CLS550, Blk M45, Lexus GX470 & an endless fleet of Avis Premium Rental Cars
http://workshop-manuals.com/mercedes...ce_and_repair/
