20 inch rim size and offset question?
Front 20 x 8.5
Rear 20 x 10
Offset - Front +20 / Rear +25
Tire Front 245/35/20
Tire Rear 275/30/20
Would this setup work ok?
Anyone know the length of lug bolt I should be using?
https://mbworld.org/forums/tire_rim_calculator.php
Try this and let us know how it works for you.
Will Mercedes Benz 20" Genuine Oem Amg Staggered Wheels Rims (20x9JJ & 20x10JJ) from a sl55 or sl600 fit on my 2006 CLS500?
I would appreciate some feedback. Thanks!
Front 20 x 8.5
Rear 20 x 10
Tire Rear 275/30/20
[FONT=Arial]Anyone know the length of lug bolt I should be using?[/
Why are you going with those sizes & offsets? Is your car lowered?
Front 20 x 8.5
Rear 20 x 10
Tire Rear 275/30/20
Did you end up getting the 255/35/20 front? Did you see above on MAXWERKS he had 255/35/20 as well.
I just purchased my first cls 500 and I would like some advice on wheels. I'm looking to with a 20 inch wheel but I want that huge lip, what off set and tire size should I go. Keep in mind this is a bone stock car and my wife drive it mostly so I don't want any issue with rubbing any where when we turn or in the rear. Also what size lug bolt will I need? Thanks all!
