CLS Coupe (C219) Discuss the CLS Coupe.
Parking Sensor Issue
Old Jan 12, 2013 | 02:05 AM
MBsd's Avatar
2009 CLS 550
My parking sensor on my 2009 CLS 550 seems to be acting up on some days. Starts to beep for no apparent reason when at slow speeds (approaching traffic lights, heavy traffic, etc). Has anyone experienced the same problem and if so, what was the problem?
thanks,
Old Jan 14, 2013 | 11:49 AM
mschamberger's Avatar
2014 CLS550
thanks,
The only time I have issues is when the cars been outside at work and we have snow/sleet. Once sensor gets covered, it's useless until it's cleaned/thaws. That's my only bad experience. I've heard heavy was buildup (especially) in the crevices can cause false positives. Other than that, check the electrical connections.
Old Jan 14, 2013 | 11:46 PM
MooF's Avatar
2011 ML63 AMG Obsidian Black
Not sure where you are from MBsd, but during cold snowy months the sensors will act up. Make sure the bumper is free of snow.
Also, here in Canada we have mandatory front plates (in Ontario) and I found the front sensors to pick up the plate cover if not seated correctly.
The sensors will alarm when you drive below 20km/hr so that's why u hear it chime in traffic.
And lastly, you can always temporarily disable on your gear console.
Old Jan 19, 2013 | 12:49 PM
MBsd's Avatar
2009 CLS 550
As an update, cleaning the sensor areas really well fixed the problem. Thanks for the input.
Old May 24, 2013 | 04:44 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
My 2006 CLS 55 goes "nuts" when it gets hot outside. I park it in the garage and its fine but in the summer it beeps like crazy to the point where I shut it off.
Old May 24, 2013 | 11:19 PM
CLSED550's Avatar
CLS, Grand Cherokee, Range Rover HSE, 70 cuda 440+6
Mine does the same. And when I go to dealer there is nothing they can do because obviously it's not doing it when i go to get it checked.
Old May 25, 2013 | 06:46 AM
MooF's Avatar
Good to know about the heat.. It's about to get humid and warm here in Toronto despite the fact it was a miserably long winter. And this will be my first summer with the CLS.
Old Jun 5, 2013 | 02:22 AM
Elrond's Avatar
CLS 350 W219
Hi, I had the same issue last winter and the only cure is to clean the car every morning . Now it is going to an error after the rear bumper was resprayed, any idea why ? What will happened to a parking sensor if it gets paint on top of it ? Could it be that there is a lose connection somewhere and if yes, do you know where is the cable connection for the rear parking sensors.
Old Jan 26, 2014 | 03:19 PM
E55AMG05's Avatar
2005 E55 AMG
COMON someone PLZ reply to this ^ I also want to know as well
Old Jun 15, 2017 | 02:12 AM
TTMBCLS's Avatar
cls550
does anybody know if you are a stop the sensor turns on? then when you drive it turns off?
