X-PIPE for 2006 cls 500
I already have quad brabus mufflers. I need a x-pipe or a downpipe to connect
it with. Please help, thanks!
Fyi :Will not make any hp difference, only sound a little smoother.
I got my 07 CLS550 today. I dropped it off at the bodyshop to touch up a lower front bumper marks. I wish I could get a view underneath it of the exhaust.
you can find much cheaper on EBAY
If this doesn't get it loud enough, a Meisterschaft system will be on order. Just trying all my options before I drop 3K.
(I wish they made headers for the cls550)
Oh yeah- the very first thing I did was a muffler delete and it sounded bad-a$$, but the drone was a bit much in the cabin.
From what I have read only,
- Off the engine the pipes run into the primary cats
- Then into the secondary cats/resonators(some refer to them as secondary cats but i am not sure if they really are)
- Then into the large resonator in the center
- Then to mufflers and out
Many remove the large resonator and replace with x pipe or straight pipes. However, I read that you should remove those cats/resonators right in front of the large resonator and put the xpipe there. Supposedly the further up the x pipe the better. The further back towards the mufflers and the sound changes dramatically.
Since Lakehouse already has the large resonator out and the x pipe there, all he needs to do is cut out the others, move his x pipe up, run straight pipe out after that to mufflers.
Cannot wait to hear it when he is done.
