Can't get windows working?
219.375
Driver 2118213679
Front passenger 2118219758
Rear left & right 2118219958; heated rear seats (code 872) 2118211551
There is window switch reset holding each respective window to upper stop and hold switch for a second or two.
Is sunroof working properly – switch on ignition move sunroof to front and rear stop and keep roof switch depressed for second or two.
Also if you have not already done so you can try pulling fuses to all DCM simultaneously in an attempt to soft reset, or disconnect main battery for at least 15 minutes for hard reset.
Interior fuse panel (dash):
f21 = right rear door DCM
f22 = right front
f32 = left rear
f33 = left front door
