Downpipes
Picked up a brilliant blue GTS a few weeks ago:-) love it!
I realize I have cheaper options but going Renntech.
Thanks in advance!
Thanks in advance!
Not sure how RT gets away with 5k DPs.
The issue with downpipes is for resale purposes, you cannot put it back to stock as the OEM pipes need to be cut out unless you want to drop the transmission (insane option IMHO).
As AMG17GT said, the deletion of the secondary cats is the way to go. I did it on mine and with the sport exhaust, it's perfect.
They are located just in front of frame support where exhaust turns 90. Very simple. On the C63 these are forward about 6-12", so it's easier on GT.
In the past, I have removed resonators which were intended to reduce drone and high frequency noise. Here it's just another 7 decibels of the same sound an octave lower.
In comfort mode it's the same except a funkier bass at idle. Yes I luv it! Ha.
That's all I have on this mod.
Attachment 353261
Why buy a mid-pipe (don't know of any vendors having them) when you can get it done and fully reversible for a couple of hundred bucks?
.It is not complicated guys.
Disconnect the battery just to be on safe side.
Cut the secondary cat with a hack saw, cut and bend a new pipe and weld new pipe on car (they have tools to weld around).
Any competent muffler shop performs this type of stuff daily.
You should not be paying more than $300 and I am including a lot of MB tax on that.
