Let's Talk About Maintenance...
Old Feb 25, 2025 | 11:59 AM
  #226
Green_Hell's Avatar
AMG GTR
2018 AMG GTR Spark Plug Replacement
RIGHT SIDE
  • Remove Turbo covers
  • Remove Vacuum Hose (1)
  • Move ME-SFI unit out of the way (5)
  • Unclip bleed line (2) and set to the side
  • Remove screws (19) from harness (4)
  • Disconnect (3) and place harness to the side
  • Remove bolts (5) and strut (6)
  • Remove soundproofing (7) to the right of the big pressure fuel pump
  • Relieve fuel pressure from port (5) below - STILL LOOKING FOR PROPER TOOL/HOSE TO DO THIS
  • Unclip harness (4) from fuel line (14) below
  • Remove the bracket of the field line (14) from the cylinder head cover
  • Remove fuel line (14) and seal holes
  • Remove screws (15), remove bleed line (16), seal openings
  • Release electrical connector (17), (23), (28)
  • Remove screws (26), (27)
  • Remove right side coil packs
  • Reassemble in reverse order before going to other side
    • Spark plug to head 22Nm
    • M6x1 9Nm
    • Vent line to cylinder head, Fuel line to engine, ignition coil to head, 9Nm
    • Union nut for fuel line 22Nm
    • Cross member and front reinforcement M8 30Nm
LEFT SIDE
  • Remove seal (34)
  • Unclip wiring harness (8) from sidewall (9)
  • Remove vacuum line (10) from booster and move upward, seal it
  • Remove screws (11)
  • Unscrew nut (12), lift sidewall (9), remove grommet (13), remove sidewall (9) upward
  • Unclip vacuum line and wiring harness (4) from bleed line (22)
  • Release connector (18), move harness (4) to the side
  • Lift soundproofing
  • Remove screw (20) and move harness (4)
  • Unscrew (21) and remove bleed line (22), seal openings
  • Remove screws (2) and place bracket with filter and sensor to one side
  • Release connectors (24,25), unscrew (28,29) and remove both coils
  • Reassemble Left side
    • M6, crank ventilation to head, ignition coil to head, wing harness to head 9Nm
    • Partition wall to body 7Nm
Old Mar 13, 2025 | 07:01 AM
  #227
Kevin#34's Avatar
AMG GTR 2021 (Euro version)
C190 series maintenance schedule RECAP
can somebody summarize which is the official service schedule for the 190 platform?
I read here and in other threads too about service A, B etc, can somebody clarify the content of each task?
specifically, what should have been done on a 3/2022 GTC with 10.000 miles on the odometer?
thanks
Old Mar 13, 2025 | 12:48 PM
  #228
G. P's Avatar
2020 AMG GTC
thanks
This attached pdf doc, is the simplest maintenance schedule document from MB/AMG, and it is accurate.
File Type: pdf
Old Mar 13, 2025 | 04:41 PM
  #229
Kevin#34's Avatar
thanks, but does that Prepaid Maintenance Coverage plan completely match what the C190 series requires? being a pre-paid plan for akmost all MB line-up of the time, ooks a bit generic to me...
I need to figure out what the maintenance scheudle for C190 models exactly requires, since I am evaluating a second-hand 2022 GTC and want to be 100% sure that all the services prescribed by MB have been done (the owner drove the car mainly during the first 2 year, then basically it became his garage queen..)
Old Mar 13, 2025 | 06:00 PM
  #230
GTConn's Avatar
2019 AMG GTC Solar Beam Yellow
2022 GTC?
Old Mar 13, 2025 | 07:33 PM
  #231
G. P's Avatar
2020 AMG GTC
Originally Posted by GTConn
2022 GTC?
They produced few 2022 GT C Roadster at the beginning of fiscal 2022, but it follows the 2021 specifications and was built on the same assembly line. The last model year for the GT C Coupe was 2021.
Old Mar 13, 2025 | 07:39 PM
  #232
GTConn's Avatar
Huh...had no idea!
Old Mar 13, 2025 | 07:58 PM
  #233
G. P's Avatar
2020 AMG GTC
The C190 platform follows the same A/B service schedule as all AMG and Mercedes-Benz models, with no special requirements. The standard maintenance includes:
  • Oil and filter change every 10K miles
  • Transaxle service every 30K miles
  • Spark plugs every 50K miles
  • ...and some other small items as per the pdf above.
If you track the car or drive it aggressively, I personally recommend changing the oil and filter every 5K miles for better engine longevity.
Additionally, a multi-point inspection should be performed to check fluid levels, consumables, and overall mechanical condition to ensure there’s no damage or wear.
So just make sure all A/B services were done (A=10K, B=20K, A=3-K etc).
As a garage queen car, I would check that the battery is still good and was never depleted.
Look at the service records for the time he didn't drive it to make sure oil and filters were changed once a year and there was at least 200-400 miles each year.
Old Mar 14, 2025 | 09:55 AM
  #234
Kevin#34's Avatar
yes, it has been registred from new on march 2022 (not sure about production date, maybe I check this from the VIN?)
2022 GTC?
Old Mar 14, 2025 | 10:06 AM
  #235
Kevin#34's Avatar
as I said, the car was driven quite regularly in the first 2 years (2022 and 2023), then just a couple of times in 2024, and probably left in the garage till now... apparently, the car is in mint condition both outside&inside and start-up normally, but we couldn't take a drive due to expired insurance...
just to reconfirm, seen that it is 3 years old and with just 10.000 miles, should have been A-serviced (oil&filter change) only ? or maybe should have been A (2022) + B (2023) + A (2024) serviced ?
Unfortunately I could not verify what has been done iat MB dealer yet...
thanks
Old Mar 14, 2025 | 02:20 PM
  #236
G. P's Avatar
2020 AMG GTC
thanks
seems like a good find. Good luck with it.
i would expect A+B+A at this point, but if not done, just take it to service B or A when you get it. For only 10k miles a skipped service is not a major issue.
Old Mar 14, 2025 | 02:34 PM
  #237
MBNRG's Avatar
A document specific for AMG GT C190 below states Transaxle Service with the 2 Separate Oil Changes for Differential and Trans are every 40,000 Miles or 4 Years, whichever come first
(Although a more frequent 30K/3 Year proposition as noted above couldn't hurt)
Elapsed Time appears to be a very crucial element as well, contributing to the breakdown of the main Trans bearing seal
Old Mar 14, 2025 | 03:37 PM
  #238
G. P's Avatar
2020 AMG GTC
While "shopping" for Transaxle service prices, three Mercedes-Benz dealers in the New York area mentioned that the service interval was changed from 40K miles/4 years to 30K miles/3 years a few years ago.
I also heard that Ferrari, which initially recommended a "fill for life" approach for the same Getrag DCT transaxle, has also updated their service cycle to 30K miles/3 years. Could be because of the relatively high number of DCT failures occurred in the Ferrari 458.
Regardless, I agree with you — it's wise to shorten the service intervals, especially for those who track their cars.
If this goes to insurance for transaxle repair approval, you know they'll point to the 30K/3Y service interval rather than the 2017 document, to try and dodge the payout.
Old Mar 15, 2025 | 12:33 AM
  #239
untamedd's Avatar
2019 AMG GT R
I just bought a 2019 gtr with 16500 kms so are you guys saying i need a transaxle service already just coz three years have gone by? Dealer did say all service is up to date and i should just wait for the next msg on dash to pop up for service but i doubt dealer would be doing transaxle and diff service at such a low mileage?
Old Mar 15, 2025 | 11:09 AM
  #240
MBNRG's Avatar
Originally Posted by untamedd
I just bought a 2019 gtr . . . i doubt dealer would be doing transaxle and diff service at such a low mileage?
Elapsed Time is just as important as mileage, if not more so, and now it's already way passed the Newer 3 Year Recommendation for Transaxle Service as noted above.
In your previous thread for Choosing Between AMG GT C/R/PRO, it was recommended to complete the Transaxle Service before you take ownership.
Would def get this service done ASAP to extend the life of the Getrag Transaxle bearing seal(s).
You can request from Dealer the Vehicle Master Inquiry to check exactly which Services were completed. If they were looking to offload and sell the 2019 GT R, very doubtful they completed the pricey Transaxle Service, even though they claim "services are up to date"
Old Mar 15, 2025 | 12:15 PM
  #241
Green_Hell's Avatar
AMG GTR
Personally, on most cars I buy I do a baseline maintenance and fluid changes - the more valuable the car, the more extensive the baseline I want under my control. I bought my 18 GTR with 19K miles from an independent used car sales company that claims to service high end cars. Oil was overfilled and they claimed to have done all B services but could not get them to document them - not even weight/brand of oil used. I did motor oil, filter, intake and cabin filters, DCT oil, diff oil, brake fluid full flush, alignment (it was WAY off, this was outsourced), corner balance, ride height. I am changing the sparkleators, coolant, and fuel filter over the summer. With this I can be assured I give the car the best opportunity for long term performance.
Old Mar 15, 2025 | 01:13 PM
  #242
untamedd's Avatar
2019 AMG GT R
you are right, you did mention that and I forgot about it with all the variables i was dealing with at the time.
When you say transaxle, youre referring to transmission service right because thats what my local dealer said when i asked them today. Seems their recommendation is still 4yrs or 60k kms but ill get these done regardless
Old Mar 15, 2025 | 01:14 PM
  #243
untamedd's Avatar
2019 AMG GT R
Thats a good approach for sure. I know oil and filters have been serviced but ill def look in to getting the diff and transmission serviced asap
Old Mar 15, 2025 | 02:57 PM
  #244
MBNRG's Avatar
Transaxle includes Both: the Trans + Differential - these 2 components take 2 very very Different oils
Good Luck; hopefully the Selling Dealership can give you a 'good will' discount for this involved service, or fully comp it, since it SHOULD have already been performed in Year 3 (or 4), and we are now on Year 6 on a 2019 Model (which is typically manufactured in 2018)
Old Mar 15, 2025 | 03:08 PM
  #245
Kevin#34's Avatar
thnaks, if I close the deal and buy this GTC, idea is to ask (=pretend) dealer to perform the missing maintenance and include it in the selling price
Old Mar 15, 2025 | 05:48 PM
  #246
untamedd's Avatar
2019 AMG GT R
bought the car out of province so no way for me to get that goodwill unfortunately. Looks like my local dealer is quoting around $1300 CAD for both. Lesson learnt for next time!
btw would you only get these done from a mercedes/amg dealer or indy shops are still good with this car? Thanks for your input
Old Mar 15, 2025 | 11:44 PM
  #247
G. P's Avatar
2020 AMG GTC
CAN$ 1300 is a very reasonable price for this transaxle service.
In order for an indy shop to do the service they need to have access to Mercedes Xentry system in order to bring up the transaxle temperature to the correct level. There are details in my following post regarding it: https://mbworld.org/forums/coupe-roa...ml#post9116143
Old Mar 16, 2025 | 01:20 AM
  #248
untamedd's Avatar
2019 AMG GT R
In order for an indy shop to do the service they need to have access to Mercedes Xentry system in order to bring up the transaxle temperature to the correct level. There are details in my following post regarding it: https://mbworld.org/forums/coupe-roadster/791702-transmission-
service.html#post9116143
i think ill just play it safe and take it to the dealer. Thanks
Old Mar 16, 2025 | 09:41 AM
  #249
descartesfool's Avatar
AMG GT-S, AMG C43, Ferrari Roma, Maserati MC20, Genesis GV70 Electrified
An independent shop just needs a scanner that can read data from the car, such as multiple Autel models like an $1100 MS906 or similar to read the transmission temperature. No need for the Mercedes system. Transaxle service procedure is easily available and has been posted on this site. There are several DIY's on here showing the details of the procedure. I did my transaxle service and it is not rocket science, you just have to be patient to get the correct temps.
Old Mar 16, 2025 | 10:21 AM
  #250
G. P's Avatar
2020 AMG GTC
There’s no disagreement here—it all comes down to what each person is willing to do and risk.
For skilled DIYers who can source the necessary materials, tackling this service can be both rewarding and cost-effective.
Independent shops are a good alternative for non-DIY owners looking to save money, but finding one with real experience handling this DCT can be challenging. Many claim they can do it, but without reviewing the WIS documents, it often ends up being their first attempt—which can be concerning.
While DCT transaxles are generally reliable and unlikely to fail for most owners, opting for DIY or an independent shop carries a $15K-$25K risk for those with an extended warranty, as insurance companies may deny coverage.
Having the service done at a certified dealer provides peace of mind for most owners. And at CAN$1,300, it's a great deal compared to a typical USA $1,800.
At the end of the day, whether you choose DIY, an independent shop, or a dealer, it’s all about personal preference.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
