AMG GT Lowering Question..
Old Apr 7, 2019 | 03:50 PM
seeubro's Avatar
2017 AMG GT
hello guys!
just wondering what would be the best lowering springs Or Coilovers or sleeves to go super low?
im looking for something really low (no wheel gaps for front & rear)
please let me know!!
thank you guys!
Old Apr 7, 2019 | 06:34 PM
Bijan Kohan's Avatar
2016 GTS; 2021 G63; 2015 Range Rover Supercharged
H&R Springs
Here is my before and after shot with H&R springs installed. Even though I wouldn’t call it “Super Low”, these springs offer a nice drop and the ride is much tighter with less leaning overall and during cornering.
The only way way to go lower is coilovers which cost 4X the price. Good luck.
Old Apr 7, 2019 | 07:02 PM
seeubro's Avatar
2017 AMG GT
Originally Posted by Bijan Kohan
H&R Springs
thanks for the info! Thats looks really good. I heard that h&r springs sits the lowest.
i just found out that ksport makes coilover and can be dropped 2.5 inch front and rear.
Old Apr 8, 2019 | 10:21 PM
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
KW ...
Old Apr 12, 2019 | 03:37 AM
seeubro's Avatar
2017 AMG GT
Originally Posted by ronin amg
KW ...
hey are you on full coilover? Or KW Sleeves?
Old Apr 12, 2019 | 09:30 AM
ronin amg's Avatar
KW springs at their lowest setting.
Old Apr 12, 2019 | 05:13 PM
AutoTalent's Avatar
SPONSOR
G55
KW HAS will drop it 1 inch in the front and 1.2 in the rear. They will ride better than the H&R as well.
Old Apr 13, 2019 | 11:32 AM
Simbad's Avatar
AMG GTS
Thread hijack alert
Curious us on your before and after rims. Were they powder coated? Ask as I am looking at buying a car with the rims from the first pic and want them black too.
H&R Springs
Old Apr 14, 2019 | 11:26 AM
300blackout's Avatar
2016 AMG GT-S Edition 1
Are you guys with the lowered GTs scraping the bottom? I usually scrape the metal brace bars under the chassis.
Old Apr 14, 2019 | 02:41 PM
No scraping as long as you drive the car correctly.
Yes - wheels were powder coated a custom dark grey satin finish.
H&R springs lower 1.2” all around. The beast feels much tighter with less noticeable flexing and body roll.
Old Apr 16, 2019 | 10:50 PM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
On RennTech coilovers---- only once over a speed bump, but I did not slow down enough. The car is so stiffly sprung so that if you can otherwise clear what you are driving over, you should not scrape if you take it easy.
Old Apr 25, 2019 | 05:05 PM
Nwills's Avatar
AMG GTS
did either of you guys do spacers as well or simply lowered the cars? Thought that when lowering the vehicle spacers were needed otherwise wheels would be heavily inset?
Old Apr 26, 2019 | 10:43 AM
ronin amg's Avatar
I did spacers just to get a slightly wider track.
Old Apr 26, 2019 | 10:50 AM
thecutter64's Avatar
2018 Solarbeam Yellow AMG GTS
what size did you use? 15mm all around ?
Old Apr 28, 2019 | 10:08 PM
seeubro's Avatar
2017 AMG GT
ive seen amg gt with 15mm front 25mm rear lowered.. looks amazing!!!!!
Old Feb 5, 2021 | 03:08 PM
morson1981's Avatar
bmw 340i
Do you have spacers on this pic?
Old Sep 23, 2022 | 06:30 PM
AMG-GT-S-2016's Avatar
2016 AMG Gt-S
Originally Posted by seeubro
hello guys!
thank you guys!
I just picked up some Renntech. I think it’s the best option out there!!
Old Sep 23, 2022 | 09:06 PM
boosted20v's Avatar
2020 AMG GT63s
How much are you being quoted for install?
Old Sep 23, 2022 | 10:22 PM
2016 AMG Gt-S
I got quoted like $500 CDN
Old Sep 24, 2022 | 07:34 AM
DCBNA's Avatar
AMG GT S
I spoke with Renntech and they said they charge 5 hours. I spoke with a couple places here and was told by 1 place 10 hours and another 6-8. 5 or 6 seemed reasonable to me.
Old Sep 24, 2022 | 12:07 PM
2016 AMG Gt-S
i think 4-5 hrs is reasonable
Roughly 1 hour on each coil
That’s what my shop said
whoever said 10hrs is either trying to scam you or they are just not experienced enough….
Old Sep 25, 2022 | 05:37 PM
Stenzel-Germany's Avatar
AMG GTR
Hi,
Depends on the package.
Remove shock absorber and disassemble, mount springs. Reassemble the shock absorber and then install it. (Not to be underestimated, some interior panels have to be removed and reassembled at the back).
All that in 4 hours I see as very fast.
But that's only half the battle. Additional to that:
Adjusting / weighing all springs,
Correct vehicle toe and camber.
Check headlights and correct, if necessary.
Check the Distronic sensor and correct, if necessary.
If you want to do everything right, 10 hours is much closer.
Best regards
Stenzel
