GTR: Oil Separator leak
Bad luck for me. My new GTR has a leaking oil separator and needs to be replaced. Found a small oil leak on the floor of my garage, brought to the dealer and they said: leaking oil separator.
Anyone knows how complex is it to change oil separator on M178? Big Job? anything to watch out for? I tried to find M178 schematics and could not find anything on oil separator, etc.
I am assuming it is part of the dry sump. Obviosly covered by warranty, but still I like to understand whats involved.
2023 Urus Performante - 2021 Ferrari Roma - 2017 Ferrari 488 GTB - 2022 GLE 63 S Coupe
It will get resolved. PDK had to be replaced on my RS in the first month of ownership. This is what happened in the first couple of weeks of owning my GTR. This should make you feel better - lol.
https://mbworld.org/forums/amg-gt/69...n-t-towed.html
Oil Seperator Diagram
Hi, apologies for quality, the attached details are from MB workshop manual and will provide an impression of what’s involved.
Looks straightforward enough, good luck.
regards
The following 2 users liked this post by phm37:
California John (12-13-2019),
tmemore (12-12-2019)
tmemore (12-16-2019)
Correction: 011010 OIL LOSS FROM ENGINE DETERMINE
611069 REMOVE/INSTALL LOWER ENGINE COMPARTMENT PANELING COMPLETE
019697 LEFT OIL SEPARATOR REMOVE/ INSTALL
831762 EXTRACT REFRIGERANT, CHECK FORLEAKS, REFILL (WHEN WORKING ONAIR
CONDITIONING)
PARTS:
000-017-03-00 SEALING RING 1
178-010-89-01 OIL SEPARATOR 1
Q-1-03-0005 G40 ANTIFREEZE
GLYSANTIN G40 1
178-094-00-91 BOOT 1
001-989-24-03-13 HYDRAULIC OIL 1
253 check for oil leak found oil leaking from left side oil separator on front of left side cylinder head drain coolant systems high and low temp drain
power steering evac a/c system remove a/c hose from separation point by service valve to a/c compressor remove a/c compressor remove power
steering pump remove left side intercooler remove low temp coolant pumps remove under panels and cross bars remove under panels remove
coolant valve on front of engine blocking oil separator remove hard metal coolant pipe and then replace oil separator reinstall all removed parts fill all
removed fluids and bleed both coolant systems bleed power steering system top off engine oil install all panels under car and road test return to
shop and clear all codes remove under panels and recheck for leaks found none clean all fluids under reinstall removed panel
California John (12-18-2019)
