AMG GT S service / maintenance cost
Old Jan 19, 2020 | 05:45 AM
AMG.SWE's Avatar
C63S AMG S205 / Estate
Hi
I'm looking at a GT S and I'm in the final stage in purchasing the car I have selected, but service B is required within 90 days.
The car is registered for traffic 2015-09 and the mileage is around 25000km so this would be the 5-year service.
Is this a major service? Did a bit of Googling and it seems like the spark plugs should be replaced.
I know that I should give Mercedes a call, but no workshop is working during Sundays.
Thanks!
Old Jan 19, 2020 | 09:49 AM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Nothing major is required until the 4 year/60k km mark. no need to replace the spark plugs now. Just do an oil change (annually), brake flush (every 2 years), and check the coolant and power steering yourself. Have them look underneath for leaks. The B Service is a waste of money, you are paying for someone to check if your lights work and your horn honks.
Old Jan 19, 2020 | 10:42 AM
AMG.SWE's Avatar
I appreciate your reply, but since money is not growing on trees in my garden I’m very careful that the second hand value is as good as possible which means that I will do all of the maintenance at Mercedes.
Since the car is in fact more than 4 years old, would that not mean that there is a big service coming up now?
Old Jan 19, 2020 | 11:08 AM
AMG 17GT's Avatar
R Nine T
No.
What Surge said is exactly correct just do “A” Services and check your own windshield wiper fluid and tire pressure lol.
I will add that everyone needs blow out their intercoolers as a bunch of dust and rocks gets in there.
Old Jan 19, 2020 | 11:26 AM
Surge's Avatar
Check the maintenance required for the 4 year mark - I believe you may need to do the transmission/diff fluid (it’s shared, at least on the electronic LSD). I think that’s it, in addition to the oil and brake fluid flush.
It’s exactly because “money doesn’t grow on trees” that you should only ask for specific things to be done. By all means, do it at a dealership; just don’t ask for the “Service A or B” or you’ll be charged for basic stuff like checking that the lights work. Up to you if you want to pay $100/hr for that.
Old Jan 19, 2020 | 03:14 PM
California John's Avatar
2022 AMG SL63
Hi
Thanks!
Here in Southern California the price for service B at an AMG Mercedes dealership ranges from approximately $500-850. Spark plugs do not need to be replaced.
Old Jan 19, 2020 | 08:47 PM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
I do the service myself on my car as per Mercedes WIS (factory service manual). It is NOT hard.
Old Jan 19, 2020 | 10:02 PM
dlefty's Avatar
/////PRO
TONS and TONS of inspect this and check that with Service A and Service B on this car. Important but no significant $ tied into that.
Change the engine oil and filter at each.
Change the charcoal / cabin filter each service B if you desire.
What MB suggests besides that:
Every 2 years: change brake fluid. Strongly suggested, do not skimp on this.
Every 3 years/30,000 miles: replace engine air filters
Every 4 years/40,000 miles: change the fluid in the DCT transmission assembly
Every 5 years/50,000 miles: replace spark plugs (I would do this in smaller intervals if tuned)
Every 12 years/120,00 miles: replace fuel filter and replace coolant
If you drive it hard and aggressive, I would suggest speeding those all up a bit to smaller intervals, if doing track days, even quicker.
Old Jan 19, 2020 | 10:14 PM
kumizi's Avatar
Designo White AMG GTS
What are you guys paying for trans fluid flush and spark plugs? Probably not many owners with cars that old lol. Want to see if my dealer is charging fair prices. Was quoted $985 for trans fluid.
Old Jan 20, 2020 | 09:31 AM
Alexfor8's Avatar
Top Answer: 1
2016 AMG GT-S | 2016 Ferrari F12
https://mbworld.org/forums/amg-gt/66...ml#post7713230
Old Jan 20, 2020 | 12:39 PM
rbf41000's Avatar
2014 MB SL 550, 2008 Lamborghini lp640, 2007 MVAgusta 1000, 2008 Aprilia Tuono, 2018 AMG GT Roadster
I was quoted over $1000 by 2 South Florida dealers for my B2 service, I am going to check with the local independent for just the oil and brake fluid change.
Old Jan 20, 2020 | 12:48 PM
Katie22's Avatar
Crap for that price I could make a killing doing the oil and brake fluid change for friends for 500................. So to do a brake fluid change it takes about two big bottles of DOT 4 brake fluid and a vacuum device. I use the vacuum pump that Harbor Freight sells for about 90 dollars last time I checked. It holds a couple gallons of whatever fluid your sucking out. The job was very easy and took about an hour.
Oil is also very easy and takes less than an hour. Add 6.5 to 7 quarts of Mobile 1 and a filter and your less than $100 dollars for an oil change.
Old Mar 4, 2022 | 11:41 AM
harristh's Avatar
amg gts 2016
can you provide any guidance as how to remove components in sequence to replace spark plugs on an AMG GTS 2016?
