Any better recommendations Than The Renntech EVM?
#176
2017 GCV, 2019 JEEP TH-E
So after further testing the ASR Module on my 18' GTR today, it does nothing for Valve open idle sound and low RPM 0-4k sound. The only difference is the cold start with valves fully open is insanely loud.
#177
That shouldn't be the case. Even in Race mode the valves don't open completely until over 4k rpms or so, so the valve will keep them 100% open even under than threshold.
#178
#179
Just went out and tested, seems you are correct. My reason for buying it was the need for wide open warm startup, but seems the only other benefit then is wide open sound while in comfort too (not that I ever use that mode, since I have the comfort suspension set in my i mode).
#180
So does this mean GTR's Valves are almost 100% open stock when exhaust is on or the ASR Modules can't get them 100% open on idle and low rev's?
#181
For my car it now has a much more aggressive sound now during start up and through low RPM range and with not much load.
This is quite noticeable when driving in traffic and say backing out of my garage.
For my car it sounds like valves are 100% open at ALL times.
It is night and day difference, you cannot mistake it at all.
Think this is what you were asking about...
#182
I'd have to say no.
#184
Sorry I just saw your reply. I ended up returning the Cete module. It did nothing of note for my 2018 GTC. Perhaps it works for other models. Certainly not what I was hoping for. That's why I couldn't tell if it was on or off. I'm just going to delete the resonators and call it good at this point.
Andrew
#185
That's the bad thing. The flaps then always remain closed.
Even at full load and high engine revs.
Best regards
Stenzel
G. P (12-21-2021)
#186
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
Speaking with Renntech about their EVM unit (which is the OEM version from ASR), I understood that their remote control fob has only 2 buttons, 1 - to open the flaps 100% and the 2 - to go back to stock. They eliminated the 3rd button to close the flaps, and therefore protecting the car from an operator mistake.
Maybe, this worth the $250 up charge between Renntech and ASR
Cheers
#187
Thanks Stenzel, that's what I thought. This of course can affect the output power, but also may damage the components up the exhaust system to the engine.
Maybe, this worth the $250 up charge between Renntech and ASR![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Cheers
Cheers
#188
First whether you buy ASR unit in EU for US$ 385.- plus 19%VAT+shipping to the USA at $102, ( paying $560), or
buying Renntech for about $605 shipping in the USA included, we are all overpaying for such a simple electronics.
Any suggestion for alternate?
So yes, the upcharge, and frankly the entire cost is an idiot tax
#189
So yes, the upcharge, and frankly the entire cost is an idiot tax![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
#190
Here is a quote from ASR's email:
..."We have an exclusive agreement with RENNtech, Inc covering the U.S. and
Canadian market based on large volume orders. We are honoring this agreement
therefore you cannot buy the product directly from Germany."...
Interesting...
#191
#192
'18 AMG GTC, '96 BMW 318i, '10 Audi Q5 (wife)
I have two support emails into Cete Automotive (Cete Automotive GmbH <info@active-sound.eu>
asking for help. The ESP function that is supposed to allow me to switch back and forth between modes is not working. I'll let you all know how they respond. Hope I didn't get a bad module, I really like the concept of the Active Valve Control, but reality isn't quite there yet. Fingers crossed I hear back and there is a good resolution.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#193
Just got RENNtech EVM for my ‘20 GTC. Works perfectly. Pushing the remote control button 1 open the flaps100% and they stay open all the time, including after shutdown and restart. Pushing button 2, puts the car back to factory default. The unit remembers the last position at startup. There is a noticeable louder exhaust sound when the flaps are wide open, either at startup, or driving at lower rev and lower speed.
I like the fact that there is no 3rd button to close the flaps, eliminating possible mistake of driving at high revs with flaps closed. The only con is that Renntech charge high premium for this unit.
daybx (12-31-2021)
#194
#196
#197
I just installed the Renntech brand EVM on my 18 GTR and just like you, I'd say there is absolutely zero change in loudness, tone, or pops when button 1 is pressed in ALL modes including idle. You can clearly hear the valves opening and closing between button 1 and 2 while in C or S but all it does is open the valves, but in the modes that the valve is open by default like S+ and Race, there is literally zero difference. Even driving in C mode the car sounds exactly the same as before by just pressing the integrated exhaust button prior to the EVM being installed. I think either the 2018 GTR have their valves fully open by default with the stock button, or the evm is just not designed to work with 2018 GTR. Will do more testing tomorrow but heavily leaning towards returning it.
57 GTR (01-11-2022)
#198
#199
Getting valves to stay open
I’ve battling a stuck exhaust flap from time to time on my 2016 amg GTS. I’ve been considering getting the renntech/ASR module. How would this work if the exhaust flaps are sticking? Would the exhaust flaps need to be open prior to install? If so, how could this be achieved? Seems like this module is a work around for sticking exhaust flaps, but if they are already sticking, I’m not sure if the module would work.
#200
Waiting to hear your results and impression of 2nd cat delete. Strongly considering doing the same to my GTC... before I waste any unnecessary money on a Renn/ASR module
