Tracking for the first time, any tips?
I will be going to the track to track my car for the first time, ever. There is a community event which will be held at the AAA Speedway in Fontana on Thursday, March 12, if anyone is interested in joining, please let me know.
Here is the info on my GTS:
MY2016 GTS
Mods:
Pure Turbos Stage 2
Catless DP's
Golabworx Tune
H&R Springs
Performance Intake
Upgraded Spark Plugs
I'm super excited to go as this is a real race track. Has anyone in SoCal taken their car to this track? What do I need to do beforehand?
I will fill up my tank with 101 Octane Race Gas, and tune my car properly using my handheld.
Any advice would be appreciated. Thanks in advance.
What about a brake fluid upgrade? Don't go on track, especially with power upgrades, without a brake fluid with a high wet boiling point around 600 degrees like Castrol SRF or Endless RF650 or Motul.
Make sure you have at least 50% of your brake pads if you still use OEM pads.
Make sure to not let your parking brake set, which it wants to automatically do. If it sets when the brakes are hot, your rotors will warp.
Also,
Have an instructor ride with you for at least a couple of sessions to teach you the basics, the racing line, passing, watching for flags, etc.
Have a tire pressure gauge with a valve. Take pressures right after you leave the track and keep them around 32 psi hot for better grip.
I let my car run for a bit after a session to keep the fluids circulating, and open the hood for more air flow.
Have fun!!!
You're either going to get your rear brakes super hot, or being very carefully managing traction on exit with that much power. But it will be lots of fun.
I expected my rear tires to get super hot battling for traction, but my fronts were the ones that took three sessions to find the right temp/PSI combo. Once I did, they stayed steady the rest of the day.
--- I will leave it in Auto.
--- Which PSI is best for front and rear tires? 30? 32? How do I warm up my tires?
Thanks again.
