Darwin Pro spoiler for 2018 GTS question
I saw some cheaper wings on alibaba from Jsk autoracing.
will the Darwin Pro work / fit on the 2018 gts? What is the quality of the carbon weave? Will it match my OEM carbon fiber?
Does the wing need to be clear coated prior to install?
is there good fit on the base so that I won’t get water in the cabin ?
thanks in advance
was the cost really under $1k. The Darwin pro is around $3.5k
As far as sealing goes, mine came with a fresh seal, which was handy.
I just got in contact with someone over there so I'll double check.
It sounds like JSK offers multiple options for the weave. Anyone know what weave would match OEM carbon fiber?
All of the part numbers above are for a Roadster - which has a different factory wing base size/shape - also, the wing has a built in brake light because the Roadster doesn't have a hard glass window with the brake light mount.
