Electronic Rear axle differential lock currently unavailable
I occasionally got this message when it rained, but it went away for weeks. The last month or so get it every day within about 60 seconds of driving. I don't have star/xentry and my MB V2.0 doesn't read any error codes from the transmission. The car drives "fine" and doesn't go into limp mode, I just get this error. I'm going to take it to a shop with star/Xentry before I go to the dealer and see if they can figure it out. The message is different to some of the other posts I've seen where someone had a similar error from an GTC.
Wondering if anyone else with a GTS has seen this error and how did they end up getting it resolved
They did update all the modules via DAS/XENTRY and the issue appears to have gone away, over 100 miles driven. Typically the issue comes up within 1/4 of a mile. Fingers crossed this solved the issue.
They also noticed my alignment was way off, had was too much toe front and back, so they ordered shims from MB and got it aligned.
There are no codes stored in the system, just the dashboard warning in my OP.
https://mbworld.org/forums/coupe-roa...ock-error.html
The problem with that error code is that it is a general error. It is not specific to what the issue is - and even with the codes read, the mechanics had to do some guesswork. In my case they had AMG's technicians look over the data. The issue on my GTC ended up being a Powertrain Control Unit module, though I never got to test it out myself as the car was bought back.
I hope they can find the issue with your car soon! All I know is that another 18' GTR had the same issue, but it ended up being some wiring in the trunk that would occasionally move out of place.
Took it to Mercedes, they found stored codes that showed one wheel reading a different speed to another. They checked the wiring harness and cabling and found no issues.
They said it could be due to my wheels/tires (I bought the car used) it has 305's on the rear instead of 295's. They cleared the codes and did a software update. guess I'll see what happens.
Feels like a lot of folks run different wheel/tires without issue so surprised if that really caused the issue.
